Turbo sidedraft 2 barrel throttle bodies
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 53
    Ada, Michigan
    Default Turbo sidedraft 2 barrel throttle bodies
    For the switch to E98 fuel I removed the old intercooler box and fabbed up this compact sidedraft 2 barrel setup.
    This will be the lowest profile setup I ever used. I'm liking this look, The top of the throttle body box is only 5 1/4 " above the manifold flange.
    The top of the turbo compressor is 7 1/2 " above the manifold flange.
    This will barely stick above the back seat.
    I added a bend in the right side compressor tube to get better valve cover access than I ever had before, it also got the bends leading into the throttle bodies on the same plane.
    I added a couple short curved sections of alum tube inside the throttle body box to try to direct the flow down,
    For the base to the throttle body box I used a leftover carb spacer that came with the Victor manifold. It already had several vaccuum ports and I added some more.
    I think I'm just going to use a couple K & N air filters like Hass did on the compressor inlets.
    The scoop I ran for years seems outdated to me now.
    Looking at this I can see where it would be easy to aim the compressors down like Impatient and Hass did and use a separate intercooler on either side of the motor if it was needed in the future for gas.
    looks great mark! you can actually use the same filter im using which has alot more surface filtering area than hass's, plus has nice chrome metal ends caps instead of jus rubber, i'll get ya the p#. is that on a dyno stand already i see?
    here's the 1 is used on my ls, gave me a place to plumb thru the injector for the preturb meth injection:
    http://www.knfilters.com/search/prod...x?Prod=RF-1037
    these are a inch shorter:
    http://www.knfilters.com/search/prod...x?Prod=RU-5147
    Texas
    Now that you can see your intake, you'll have to polish it!
    Nice!
    Ada, Michigan
    Quote Originally Posted by Filucky View Post
    I was thinking the same thing.
    At least part of it.
    Ada, Michigan
    That's a combination cart and dyno stand.
    I may dyno again in the spring just to see what difference the E98 fuel with no intercooler made.
    It should recapture about 2# of boost from the intercooler restriction.
    Derby, Kansas
    Thumbs up
    Looks good Mark, from the asthetics point of view I like it alot better than your old intercooled set up. Hopefully it does what you want.
    Nov 2008
    Orangevale CA
    And the BLOCK - HEAD'S TOO ,lol, .....E
    okie, lake Texoma
    That looks Damn killer Mark!! I like it.
    H8-2-W8
    [email protected] first pass
    okie, lake Texoma
    Damn Tom. Those are the same size as mine just with the chrome cap(well mines 1/2" taller than yours)
    Here's the one I have http://www.knfilters.com/search/prod...x?Prod=RU-2800
    H8-2-W8
    Green Bay Wi,USA
    That looks too good, you have to mess it up a little or you will lose your Hack status.
    oh i thought the bottom link i gave him were your's you sure your's is taller than mine? we measured mine and couldnt put them on bill's even without the charge tube on it, they're jus wasnt nuff space to put 1 on each inlet, let alone put the charge tube in between them.
    okie, lake Texoma
    The link I put up is definately the ones I'm running maybe you got the wrong one.
    H8-2-W8
    okie, lake Texoma
    Hey Mark, I dare you to tape some eyeballs & a mustache to the front of little box
    H8-2-W8
