Would a new ZR1 motor work in a boat
Page 1 of 9 1 2 3 4 ... LastLast
Results 1 to 14 of 124
    Senior Member bad news travels fast's Avatar
    San Jose
    Default Would a new ZR1 motor work in a boat
    I have been going round and round about big inch na. motor vs. supercharged lsx motor. The numbers on the ZR1 look so good it is hard to ignore. 638 Hp, 600 ft lbs touque, 500 lbs weight. Idles nice and low, but turns 6600 rpm. Boat is a Stoker 224. I notice such a difference in the handling of the boat when a run half of the 50 gallons of gas, that pulling 300 lbs out of the arse would seem like a great idea. First, what does a tall deck bbc weigh? Second, what would it take to make a ZR1 marinized? The boat runs right at 80 with a 496 Mag. with Dana exhaust. How much does marinizing a motor add to the weight?
    Tommy
    Somewhere between Paso & L.A.
    If I remember right, that boat( I wanted one real bad) would run 95mph with a stock
    merc hp500- how fast do you want to go? remember, outdrives don't live very long above
    5800 rpm (stock bravo anyway) where does that engine make that torque figure?
    cfm
    cfm is offline
    Concord, CA
    Default Zr1
    I beleive the ZR1 engine is a 427 cid. the LS3 is 376 cid.
    Just bought the wife a corvette. She let me drive it, and WOW. Cruising around, getting on freeway a little aggressive, running up to 80, and never went over 2,100 rpms. The HP/Touque specs show the power to be in the 5,500 rpm range. Watched some video's of stock trim Corvettes at 200mph and 5,200 rpm's. Might have to switch from boats for the thrills now.
    In a boat, These motors should good. I like your way of thinking,
    Jerry
    Texas
    That new ZR1 is baddass for sure, and i'm a Ford guy. But i'd guess a ZR1 crate motor complete with ECM, wiring harness ect. would be some big bucks. As cool as it would be it would be hard to justify when you could build a 700hp pumpgas N/A BBC for probably half the cost. But it would be different for sure.
    Nice!
    Senior Member gregb's Avatar
    Redondo
    If you haven't been down to the jet section, there are 10 pages or so of "spirited" discussion about LS vs BBC.
    Quote Originally Posted by Filucky View Post
    A crate LS9 is right around $23,000 without the ECM. The first thing I would think about if using any of the crate LS motors, is looking at the ECM programming. No duubt the motor will run and the boat perfrom pretty well. But you have to rememeber the Vette is saddled with all kinds of CAFE and EPA regs it has to meet. At any thing less than WOT the ECM is constently try to maximize fuel consumption and minimize emissions. It will do what it takes to maximize the milage and minimize the emissions any way it can within its programming. That means it will try to shift a transmission that isn't there. What does this do to the engine parameters if the ECM doesn't see the Rs drop when they should have. What does it do next. Does what it ECM does in a case like that effect the performance of the engine? What does the ECM do if the engine temp doesn't come up to temp fast enough or high enough. Does it keep the fuel ration rich think the motor is cold and retart the timing to try and get the motor warmer, sooner. the time it takes a motor to get to temp is ctrictical to passing EPA regs. Do you know what GM wrote into the program to help speed that up, and what the engine is doing when it is below spec temp? Any of the LS motors really should have a custom written program for marine use.
    San Jose
    GN7, all good points. I hadn't thought about the computer smog stuff.
    Fillucky, as far as building a 700 hp bbc, it can be done but if you build it for endurance; ie, 400 hours with efi you sre in the 30k plus range. There is also the fact that I like the idea of shaving 300 lbs out of the arse of the boat.
    Thanks for everyones input.
    Tommy
    New here Beer:30's Avatar
    Bakersfield, CA
    Quote Originally Posted by billet racing View Post
    Jerry
    Nope. The ZR-1 motor is 6.2L. Not 7.0. I have been looking at the Camaro ZL-1 (SLP), which has a supercharged 7.0L. 750hp is the number on that one.
    Senior Member bp298's Avatar
    LHC
    Quote Originally Posted by bad news travels fast View Post
    Tommy
    ?? the crate gm572 is 13k, will last just fine. and if you wanted to go nutz, a 572 making 800 on pump gas can be done for under 20k, running, and will last for a long long time. just sayin...
    Right you are Beer, the ZO6 has the N/A 7 litre/427
    At 80K PLUS the price of a SS Camaro, you can have the thing.
    The GM 572/620 has been dyno by 2 different mags and both came up with of 650HP. You could hit 750 doing nothing but changing the cam, and carb to somehting more realistic to a 572 inch motor. An 850 carb on a 572? Really?
    I would love to see those 2 motors in identical boats running balls out till the first one failed.
    Bakersfield, CA
    I agree. I am having a rough time deciding if a 1-of-69 car is worth six-figures or not. I have always missed the limited edition stuff by a few buyers. I was gonna get one of the ZL1 (BBC) all alum 427 ENGINEs, but missed it. Now the guys that have them want 10K more than they were originally.
    SLP sent their sales rep out this last weekend to my local dealership. He brought a ZL585 (10psi into an otherwise stock 426hp SS), which I added 20 miles to. Real nice car. It had the Brembo brake package (15" front and rear) and those are amazing themselves.
    52 are sold, so I have to buckle-down and decide. I'm guaranteed it will be one of 69 for THIS bodystyle. He could not guarantee that the owner wouldn't do another ZL-1 in any future bodystyle of Camaro. I just wish I could tell what the future will bring. If I knew it would be worth 400-500K in 40 years like a '69 is - there would be NO hesitation.
    Texas
    I know which one i would put my money on, for endurance its a no brainer. BBF
    Nice!
