Valves
Results 1 to 13 of 13
Valves
    Cole SS cole ss's Avatar
    Rochester, wa.
    Default Valves
    When putting bigger valves in bbc heads should you use a special inconel exhaust valve. Would my stock peanut port heads have these, and how would you tell? What are the pro's and con's of using them or not? I want to use different heads.Confused. Thanks.
    Quote Originally Posted by cole ss View Post
    seriously doubt your stock peanut ports have inconels. They really aren't that neccesary in something less than a HARD running N/A, some if not most blower deals and ALL turbos. Its very difficult if not impossible to tell by looking.
    Pros, take heats exceptionly well. Its why they are required in turbo deals, and should be used in almost any good running blower deal or hard run N/A. Hard run doesn't mean you hold it to the floor for a whole 2 minutes. It means your pushing an offshore boat with 750+ hp for an entire race.
    There are some very good SS valves out there from Ferrea and REV that will handle 99% of all the N/A motors running. And do it for less than 1/2 the cost of an inconel. When you see the price of an inconel, your wallet will jump and shake.
    Placentia, CA
    Ferrea is now offering "Super Alloy" instead of inconel, supposed to be better.
    steveo143 AKA DiMarco 21 II
    Quote Originally Posted by steveo143 View Post
    the price tells you its better
    okie, lake Texoma
    I used them in my last turbo deal and had absolutely no trouble.
    This is a copy & paste from there site.
    VALVES TECH
    GENERAL GUIDELINE FOR FERREA VALVES APPLICATION
    TITANIUM VALVES:
    These valves are used in professionally built high rpm (above 8000) roller or flat tappet racing engines.
    Applications include Drag Racing, NASCAR, Oval & Sprint Car, Road Racing, and Motorcycle.
    SUPER ALLOY:
    Special extreme duty Hi-Temperature Exhaust Valves. For use in Top/Fuel, Funny/Car, Supercharged,
    Nitrous, NASCAR, Sport Compact, Off-Shore Marine, 9.0 to 1 compression restricted carburetor motors
    (extreme exhaust temperature present).
    HOLLOW STEM and HOLLOW STEM SODIUM-FILL VALVES:
    The latest addition to the Ferrea Series. These Hollow Stem Lightweight Valves are manufactured
    with a unique process that gun drill and micro polish the hollow stem. For the Sodium-Fill Valves
    we add a specially formulated sodium into the hollow stem. The use of these valves achieves a weight
    reduction (20 % compared with a conventional stainless steel solid-stem valve) and a higher rpm’s with
    the hollow stem valves and also a better heat dissipation with the sodium fill valves. Applications for
    Domestic, Sport Compact and Motorcycle markets.
    COMPETITION PLUS:
    Extreme duty racing valves, engineered for high rpm, high horsepower racing engines. They have
    exclusive features, which makes them the best flowing valve on the market with unequalled performance
    and reliability. Drag Racing, NASCAR, Oval & Sprint Car, Road Racing, Sport Compact, Motorcycle
    and Off-Shore Marine.
    6000 SERIES:
    Competition valves with higher fatigue resistance and tensile strengths than our competitors’ best offering.
    These valves are made to withstand high spring pressure, roller and flat tappet cams, Drag Racing, Oval
    Track, Road Racing and Sport Compact.
    5000 SERIES:
    Hi-Performance stainless steel one piece forged valves, fully machined, hard chrome, and hard tip.
    These valves are excellent for Hi-performance Street, mildly modified Drag Racing, and Oval Track
    applications.
    H8-2-W8
    [email protected] first pass
    Yeah, I have them in one set of heads as well. They are the chit. I REMEMBER buying them very well. I remember much better than when I bought the inconels. I thought I was buying the heads also. But nope, just the valves Most pleasure boats could get away with 6000 valves and the rest could use Competition Plus valves.
    Texas
    Ya but does it improve head flow numbers? Just kid'n, i wont post on this thread anymore.
    Nice!
    Placentia, CA
    If you don't drop a valve, they are worth every penny. Running them in the rebuilt 19' Schiada twin turbo deal.
    Hey Bob,, the Ferrea Super Alloy valves have actually been costing me considerably less than Manley Inconel
    Now why don't I find that hard to believe. maybe why I haven't bought a Manley in over 5 years. Reguardless of the valve material. Strictly Ferrea and REVs
    Just so you guys know, Inconel is a register trade name like Kleenex, or Freon. Ferrea Super Alloy is not that far unrelated. the name was just changed to protect the guilty.
    The people at Ferrea told me the Super Alloy was developed in conjunction with Mercedes Benz and their turbo engines, and their claim was that it's good for 700 degrees more than an Inconel valve.
    Whether or not that is true, I have no real way of knowing.
    Somewhere between Paso & L.A.
    I have always used Ferrea valves since a circle track buddy turned me on to them.
    they are a very high quality piece at what I call "affordable" just for piece of mind!
    GN7 is the only one I have ever heard of losing the head off of one, but we all know
    how hard he runs his stuff!I have generally used the competition plus series
    with very good results even in blown applications, but they were not endurance RACE
    engines, just cove racers/lake boats- in the endurance area, like GN, OFFSHORE, etc
    buy the best you can afford.....JMLAO
    Quote Originally Posted by Blowncat 509 View Post
    That thing had to be a freak. If I didn't thing it was, I wouldn't run them anymore. I have never seen a valve fail like that. It wasn't a matter of running it hard. It failed in the very first race. And yea, we run the hell out them, and never failed another. I held my breath for awhile after that. But not anymore. We beat the hell out of set of exhausts when the crank snout snapped. Got 6 out of 8. Not one even cracked. And two of them were really jacked up.
