AFR 305's...what's with the vane?
    Somewhere between Paso & L.A.
    Default AFR 305's...what's with the vane?
    here's a couple of pic's of my AFR 305's......just wonderin' if anyone knows about the vane
    in the intake port, and why it is removed in their 315cnc head? I didn't remove it, all
    I have done is square stuff up, and remove casting flash--I'm not made of money, and
    didn't feel my application warranted the extra 10cc's and the $1000.00 that comes with
    it for those that don't already know, these are going on a 509cid engine with a
    Whipplecharger, and Bravo I drive, in a 25' cat......planned max rpm is about 56-5800
    all I am worried about now is how long my drive is going to last
Name:	AFR 305's 002.jpg
ID:	100920   Click image for larger version.
Name:	AFR 305's 005.jpg
ID:	100921   Click image for larger version.
Name:	AFR 305's 001.jpg
ID:	100922   Click image for larger version.
Name:	AFR 305's 004.jpg
ID:	100923   Click image for larger version.
Name:	AFR 305's 006.jpg
    Its not gone in the 315. Its there, its just much less pronounced. Its there even in the 357 cnc'd head, just lower and shorter. As the port gets larger in volume, less and less of the vane remains. It takes up space. The manifold opening of the 305 thru the 335 is the same. So the extra volume didn't come from making the port bigger everywhere. Mostly the vane flattening and the pocket area.
    Jan 2010
    So Cal
    Pretty shinny runners
    Just curious, Does the theory of leaving the intake runners rough to promote atomization only apply in NA motors?
    Actually, the backlight and the flash kinda added to the bling factor- just 80grit roll,
    then hit with a scotch brite flap! ( you don't think I should break out the compound
    and the polishing wheel?)
