Pfm / banks exhaust manifolds
    Senior Member LOLYFE's Avatar
    Idaho
    Default Pfm / banks exhaust manifolds
    Does the PFM twin turbo kit need specific exhaust manifolds, meaning that on the manifolds themselves one is longer than the other to make the turbos the same length to hook up carb adapter? Are the banks the same?
    Placentia, CA
    That would be a big Yes! Need some?
    steveo143 AKA DiMarco 21 II
    Senior Member tomply32's Avatar
    palm beach florida
    Default turbo manifolds
    a lot of the exhaust logs are staggered already to compensate for the head configuration maybe some of the old logs were not cant tell you that.i just pulled a set of hardens off the shelf to see the actual measurements against an original gale banks set very close .close enough that your hose would make up the differance.just make sure you ask if the manifolds are even or if one is longer and you are good to go
    palm beach florida
    Default exhaust manifolds
    forgot to mention i have both a pfm and a gale banks set up .they are almost the same depending on which kit you have
