PROS AND CONS Needle and Seats
Results 1 to 8 of 8
    Default PROS AND CONS Needle and Seats
    Bottom Feeder Needle and Seats
    Has any one used these? Seems they would be a good choice for marine engine usage.
    Cantard 71hallett's Avatar
    snow bank
    They will keep the fuel a little cleaner in the bowl if you get what I mean. Instead of spraying around in the bowl from the top...... does it make a difference....not really unless you need something that will let you keep the float level down a bit. (off road hill climb exc.)
    Kingman/Golden Vly, Az
    i have several sets...havent tried them yet, but, i have heard good things about them ...i got mine off of EBay...made by AED p/n 5116 with nylon gaskets & o-ring...just info for those interested!
    FastRat
    Think about it. The needle and seat isn't really the problem. The bowl is. Reguardless of how the fuel leaves the needle/seat assembly, its not in the "jet area" yet. The fuel still enter the bowls's float/holding chamber the same way reguardless of the type of needle assembly. They are a little better, but by how much? Now if you really want "clean" fuel in the bowl, you have to fix the bowl:
    LINK: fuel bowls
    Seems better flow, and less required fuel pressure would be benifiacal. The Braswell stuff is nice, and light as well.
    Atlantic Beach, FL
    I have used them. The idea is to reduce aeration of the fuel in the bowl by dispensing the fuel below the fluid level, instead of over it. Seems logical, but couldn't tell you if it's a significant benefit.
    http://www.blp.com/pdf/install/BLPFloats.pdf If you look closely at the picture of the carb in this link, they have cut out the sides of the bowls and put in a big window so you can see all the fuel. The bowl on the left is all foamy, and the bowl on the right with the bottom feed shows how clear the fuel is. To me it looks like the fuel in the left bowl was in a blender first, but that's just my observation, not sayn' they fixed the demo...
    That was my intial observation too, cleaner fuel.
    I get it, PICK ME PICK ME. M
