850 mighty demon carb tuning?
Results 1 to 14 of 21
    Senior Member hotbo's Avatar
    lake Ouachita AR
    Default 850 mighty demon carb tuning?
    okay fellas here is my questions
    the motor i built for my uncles lp is doing great
    it has a rpm air gap and a 1inch open spacer.
    850 mighty demon{not my choice but does good nevertheless}
    okay here is the problem.i ran it hard this evening.pulled plugs #1 is to rich-#2 is bout right all the rest are way to lean,almost scarey lean.
    what should i do.if i jet it up well thats gonna hurt the #1 more and take #2 from bout right to worse.
    ????????????should i do away with open spacer,put 4 hole spacer or what,any help i will be thankful
    demon carbs suck imo but im stuck with this one b/c he loves it,lol!!!!!
    After reading the post, what kind of idle time before shut down and do you have a feul pressure gauge and pressure readings thru the day. M
    lake Ouachita AR
    5-6 psi with stock fuel pump idle time thru no wake zone back to the boat ramp,run the boat about 1 hour off and on 2 wot passes the rest of the time was cruising 3-4 grand.turned a a/b agressor impeller 5100 rpm max speed 65.2 in a taylor lp 21 foot heavy as hell boat,does that help cutting impeller and adding some more timing to try and make it gain some speed and turn more rpms,but im afraid to do anything till i get the carb tuned in some more,
    Hotbro, Take the boat out with a plug socket and make a good pass. Slow down asap let cool alittle the pull the four corners of plugs on the motor,(or if you have time pull all the plugs and take a visual) It really is amazing how fast the color of a plug will change with 3 to 5 minutes idle time. Depending on mixture screw settings, manifold and timing. Might tell you another story. Lite tan plugs mean good feul to air ratio, If cyclinders come up up still black run a combustion check and see if things are close. Even is perfect 15% is acceptable. Good Luck M
    Lexington, KY
    Exclamation Here's your fix!
    DuaneHTP told me to use this under mine. I haven't done it yet because I don't have the money, but my engine hasn't been run yet, so I can't tell you anything about them. But, Duane told me that this solved that problem on the dyno runs.
    http://www.highvelocityheads.com/ss.htm
    Duane is the guy to talk to about the Demons!
    HJ
    Newton Ks.
    Buy a Holley.
    Now, any mixture reading with cruising time or idle time on them are not really worth a damn.Dragstuf.com How To Read Plugs
    H.L. Mencken
    Cantard 71hallett's Avatar
    snow bank
    x2
    Wishin I was at the lake! Brian's Avatar
    Cave Creek, AZ
    They call it "plug chop" for a reason!
    If you want a reading for a particular condition, run it at that condition and shut it down asap (even coasting to a stop), then read plugs. Don't idle back to the ramp and then expect a good reading...
    Duane dislikes the Demon's, Super Suckers do help!
    The problem lies with BG claiming their carbs are a much bigger CFM than the stated model. Like an 850 flows 900 plus CFM, too big of carb, results in loss of draw thru the veturies. This results in lean conditions with BG carbs.
    New Jersey
    Will the Super Sucker help a holley on a single plane manifold? What does it actually do?
    Doug
    lake Ouachita AR
    okay my question is 4-hole spacer gonna be better than the open spacer or just do away with the spacer all together
    i know how to read plugs and to really get a good reading yes you are suppose to make a cruise run with no idle time or wot pass then kill.
    by just lookin at a plug you think you may be reading it but in reality you need to look inside the thing towards th bottom of the electrode not just the outer part.anyway just trying to find a happy meduim
    cfm
    cfm is offline
    hotboat - what kind of intake ? I forget. Yeh, getting old and too many motors to keep track of.
    And yes, the BG's typically flow way more when flowed dry. So, when going by same train of thought with standard Holley's, this can through you off.
    Any pepper on the inside porcelian ?
    cfm
    cfm is offline
    Is this the motor in question ?
    "heres what i have a 9.1 781 heads 2.19-1.88 valves comp 294 solid,248-595 110-106 "
    What cid ? What intake ? Does that stae you have 9.1:1 compression ?
    Sorry, your different threads and different motor builds have me confused on which engine you are talking about.
    Can't follow and remember everything.
    Thanks.
    lake Ouachita AR
    Thanks.
    my uncles mill,9.5-1 flat top .100 over bore bbc 475 c.i. closed chamber oval ports,2.19-1.88 valves.comp hyd roller.242-248-296-302-566-566,112-110.
    performer rpm air gap-850 mighty demon.i put a 1 inch open spacer under it.
    #1 is too rich for me-#2 about right light tan.all the rest to lean to me.little black around the begining of the threads,the porcelian look almost as white as they did coming out of the box.tried to look down inside as best as i can.but hard to see.notmuch if any color down inside on the porcelian.sorry spelling sucks.
    wondering if it would help or hurt by doing away with the open spacer.
