Turbo piping almost done....:)
Results 1 to 14 of 29
    spokane, WA
    Default Turbo piping almost done....:)
    Here are a few pics of the hot side I built, going to do the cold side in the boat when the air to water IC shows up soon. Still need to build the turbo supports off the back of the heads. Thanks for looking.
    Travis
    spokane, WA
    more....
    Cantard 71hallett's Avatar
    snow bank
    Looks sweet!! What turbos are you using?
    Ada, Michigan
    That's looking real good.
    It should be easy to make a simple heat shield to cover the header tubes.
    That's A lot like the configuration that Mike W did.
    It's good to see that guys are getting away from mounting the turbos over the valve covers. That always looked like bad engineering to me.
    Senior Member Here Comes Whitey's Avatar
    Budweiser rd hit squad
    With the right headers you can lash the valves with out removing anything with the turbos above the valve covers Why do you say its bad engineering.
    Most guys doing the turbo stuff do it this way, seems more the home built stuff mounts them way back. Just curious on your thoughts.
    In my opinion looks cleaner above valve cover.
    Those look like big turbos what are they? Should make good power. Card or efi?
    spokane, WA
    Thanks mark! I am on threturboforums as snyper and I liked the way Mike did his set up so i kind of followed it. The turbos are Borg Warner S400's T6 1.10 ar on the turbine, guys are making 1600+ with a pair of these on a BBC. I went a little over kill with my set up for this hull but plan to upgrade to a better one next year.
    The headers are 2 inch primaries with 3 1/2 collectors to the turbos, I went with a 900cfm C&S Dual needle and seat carb.
    Thanks for the input guys!
    Travis
    Thumbs up Valve covers
    Then there is those guys who mount their turbos TO the valve covers . . . . . what's up with that!
    Seriously, looks good TT540!
    LSR
    Tower Park Resort, Lodi, CA
    Lookin' good Travis! Can't wait to see some video of that thing. Carb's a MONSTER! What Compression Ratio did you settle on?
    -Seth-
    Ada, Michigan
    Quote Originally Posted by Here Comes Whitey View Post
    Would you say that the access to the valve train is better with the turbos mounted over the valve covers or behind them ?
    I built my own because I hadn't found anything that looked like it made sense to me. When you are building your own, accessibility to all engine components is a factor in how you do it. You are not limited by the way someone else did it.
    spokane, WA
    I am going with 8.75 to 1 on this set up, that with an air to water IC and the big turbos I should be seeing some big hp numbers on pump gas!
    I also chose to build my own headers for a couple reasons, one because just what Mark pointed out. I could build them just how I wanted to in order to get to the plugs how i wanted and the valve train. The other is it saved me a ton of money wich is nice for those of us with not so deep pockets!
    Mark,
    If you get a minute I really need a cam speced for this set up if ya dont mind? Im having trouble picking the right cam as this is my first real boat engine, solid roller.
    540 dart block
    single plain intake
    900 cfm C&S carb
    oval port cast iron heads, 2.19/1.88 on the valves
    6500 rpm
    Thanks if ya can help!
    Travis
    TJS
    TJS is offline
    CT
    Looks good Snyper..uh er TwinTurbo540. Have you posted this on TurboForums yet. Nice Job Man.
    T.J.
    Senior Member I DIG IT's Avatar
    spokane WA
    Hay Travis it all looking really sweet, Summer is comming. I think that you are going to spank the old CP. It's all going to be alot of fun anyways how much longer do you think it will take to get her all back together???
    spokane, WA
    Brayden, whats up man! Not sure when it will all come togeather......probly mid june? Its been so cold here I am just not to motivated to crank on it. Also just tore the whole deck off the house and am building a new one around the pool, getting the pool open and putting all new grass in the back yard. LOL, to much shit going on like always!
    Travis
    Ada, Michigan
    Quote Originally Posted by TwinTurbo540 View Post
    Picking cams is not really my specialty but I would go with a 114 to 116 lobe center cam and keep the duration down to keep the overlap down.
    I started out with a big cam and have progressively downsized.
    Big cams put huge stresses on the valve train. After the engine ate lifters a few times I'm done with that.
    Now I'm at a .630 lift and duration at .050 is around 250 degrees. It's a 116 lobe center. The turbos will make so much power that it's going to scream even if you had a stock cam in it.
