To Puke or not to Puke tank
Results 1 to 3 of 3
    Default To Puke or not to Puke tank
    My last blower set up had MT valve covers, with rubber grommet O rings for 3/8 inch threaded elbow ( -6) fittings to push through. From there it was 3/8 inch hard line to the puke tank. I was not pushing alot or if any boost with this set up.
    The next build will be with an intercooled 8/71 and plan on some boost. So my question is I would like to keep the puke tank, But will the 3/8" lines be enough for volume effieciency, since I see most set ups with -10 or -12 hoses from valve covers to the tank.
    My thoughts are with the hard lines possibley rerouting them to maybe the upper portion of the back side of valve covers to keep a low profile, giving me the option of utilizing an engine cover with cut out for the blower. V drive set up, so the puke tank is mounted on the back side of the motor, front side of the boat.
    Thank you for thoughts and expeirence suggestions. Brian
    My experience with puke tanks are to get them as high as possible and use as big a line as possible. That large lines flow volume without velocity and any oil left in the lines can flow back.
    We ran -16 lines from both covers to a tank mounted about carb high on the back of the blower. But you'll still make lower end pressure. Your doing nothing to lower it, your just venting it.
    The exhaust extractors will at least pull a vac on the lower end. If you lower the pressure even a little, it helps. If you can actualy pull some vacuum, even better. But why settle for just venting it.
