cylinder heads
Results 1 to 6 of 6
cylinder heads
    Retired Air Force Master Sergeant's Avatar
    Lake Havasu
    Default cylinder heads
    What is the largest engine a set of CNC ported 335 Dart 1 heads would be good for at 6300 RPM? (BBC)
    Quote Originally Posted by Master Sergeant View Post
    Marine app? 588, 632, especially if you had a 2.400 valve installed, but even with the 2.35 they'd work fine.
    Lake Havasu
    Yes, for a jet
    Unless its a 572 with a single 850, in an 10,000lb offshore boat spinning 5300. Then the experts will tell you nothing smaller than 357 cnc
    Lake Havasu
    I want to buy a new short block and am having trouble selecting a size. I would like to use my old heads if possible.
    Like Steel said, at that RPM you'll have a tough time buying a short block that is too big for those heads.
