kool fuel pro charger?
Results 1 to 3 of 3
    Default kool fuel pro charger?
    I picked up a procharger with intercooler. I know nothing about running a blower. my 502 mag MPI has the mercruiser water cooled fuel pump. someone told me it would be enough fuel to run mild boost. anybody? if I put it on, how do I tune it?
    I'd be more concerned whether your injectors can keep up. And I don't think your motor is going to be to happy with the stock programming in your
    ECU. Your probably going to need a re-programming. Try Arizona Speed and Marine. And no, you can't tune it.
    LINK: AZ Speed & Marine ECU re-progam
    Ada, Michigan
    Quote Originally Posted by OkieDave View Post
    Dave,
    The stock Mercruiser EFI is only going to have a 1 bar MAP sensor.
    All it reads is vaccuum, it would'nt know what to do with boost pressure.
    Also every # of boost pressure will reduce the fuel pressure by the same amount so it needs to have a regulator with a boost referrence port.
    Give me a call if I can help you out. 6168137237
