read this
Results 1 to 2 of 2
read this
    Member nordic 572's Avatar
    Mar 2011
    Default read this,hope it will help those headachs
    1,454,4 bolt block blue print +.030 gen 5
    2, 2 g.m.p.p.alum heads w345 rnrs,+.100 manley svr duty225/188w/wide bodys,girdle,ported
    3,1 454 steel - .10/.10 crank,
    4,8 6.385 rods h beams w/arp l 19 bolt option,270.000#tensile strength
    5,pro charger m3sc w/504 intercooler,cool fuel,for mag merc,mpi 454 polished complete kit 5#pulley
    6,1 set custom push rods made for the valve train above
    7, 8 aris +.030 blower pistons w/tool steel pins
    8, 8 502 7/16"stock rods, will add arp bolts +recontition
    9, 1 merc mpi intake w/stock injectors,vst will be eliminated
    10, main/head 12,pt arp studs,all bolts arp,arp long rocker studs,for large axel in wide cranes
    11, 1 2qt pan w/scraper,trap doors,oil pump supports,full milodon diamond stripper windage tray
    12,1 msd dist,billet,and msd 7ml2 ign box,20 m.m.sleeved wires
    13 ,8 top of the line comp cam hyd rollers
    14,billet sea pump,gil strainer,low water transom p.u. for intercooler
    15,billet fully adjustable t chain
    16,e.m.i.thunder exhaust alum manifolds, w/silent choice, my questions what rings,end gaps,and gap spacing,piston to wall clerance, good cam recomendaition,emi wet/blower.dont think long rod will work w/pistons,4"stroke,need big pump,boost fuel reg reconendaitions,for got to mention 50#injectors,wont be enough,also can i do to mutch injector,may go 7#pulley,sorry bout hard reading my other post. i hope this prints like it looks on the box im in now! well here goes and thank all you guys that tried to help me, boat guys/girls are the by far the best the world has to offer sincerly kevin s p.s. this is going in a nice velocity 26,bvo 1ext steering looking for tabs ant guesses as to h.p. after dynotune,ecm reprogram,how bout top speed 1/2 fuel 2 people
    Quote Originally Posted by nordic 572 View Post
    1,
    "one comma" ??
