olds main and rod spec
Results 1 to 7 of 7
    Member E Rock's Avatar
    Jun 2010
    Tulsa OK
    Default olds main and rod spec
    what are you guys running on the olds for main and rod clearance? only wanna hear from the peeps that have a tried and true set up. lol....don't wanna burn a crank up again..
    seems like I read .001 for every inch, is that standard for olds?
    Lake Havasu az.
    Quote Originally Posted by E Rock View Post
    .003 rods .0035 mains...no restrictors drilled drain backs hv pump 50wt vr1 max rpm 5100...still looks good after 40+ hrs. in a v-drive
    Sheriff Joe Arpaio
    Quote Originally Posted by Sold honda.bought hondo View Post
    .003 rods .0035 mains...no restrictors drilled drain backs hv pump 50wt vr1 max rpm 5100...still looks good after 40+ hrs. and a barn burning firein a v-drive
    How did you forget to leave that out?
    Senior Member lbhsbz's Avatar
    Long Beach
    That's not right
    Yeah I know. But I think he is over it by now, and has moved on to a better piece
    Hey Hondo, how the hell did that happen anyway
    Lake Havasu az.
    Gezuz......the crap i gotta put up with some time
    Sheriff Joe Arpaio
    "Mad" Member Jet Mad's Avatar
    Cape Town, South Africa
    I run .0030" Mains and Big Ends, after market rods with ARP bolts.
    Rods slotted both sides.
    Wikus
