Marvel Mystery oil
Results 1 to 12 of 12
Marvel Mystery oil
    Jun 2010
    Default Marvel Mystery oil
    Thoughts, opinions -worked good for me to loosen up a mystery motor today---and I heard it don't hurt to add to the tank....
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Believe it or not the engine will run on it 100%.
    QE 439 Twin Turbo
    Broke mo fo djunkie's Avatar
    Lomita, Ca./ Havasu
    I was having a problem with my carb floats sticking. Ever since I've started adding it to my tank at fill ups the problem with the floats has disappeared.
    The beater!!!
    Senior Member bp298's Avatar
    LHC
    Quote Originally Posted by mdsheppie View Post
    it's only useful for engines that make horsepower...
    I've been using it for well over 25 years in HP toys. Blown or turbo running on 50% AV or better, I use 1/2oz per gallon.
    058 is offline
    I use it to oil my air tools...works great.
    I have heard it is a torque killer
    seriously, you have to be carefull when adding it to a fuel. It is a octane killer. So if you think you are on the edge of detonation, it will push you over the edge. Not suggesting or telling anyone that is running it they should stop. Just be aware that it does lower your octane.
    I have always question the use of it in AV. The whole "AV is dry" thing is a misunderstanding. When they say dry, it means lack of moisture. Imagine being at 10,000 ft and ice forms in your fuel. Could ruin your day.
    Lube of AV fuel? Aircraft pistons and valves and rings and ........ don't need lube so they took it out. Seriously? And putting Marvel in is the solution?
    Now on a E85 or Meth deal, whole other story.
    Nov 2008
    Orangevale CA
    Marvel mystery oil Does NOT mix with Methanol .
    I have used Blendzall Racing castor (bean based mixes with Methanol) , ( talk about a Sweet smelling fuel when burned )!! lol, .......... E
    [QUOTE=J Shelfo; My all time favorite quote; Flatbottoms are like shopping carts, every once in a while, you get a good one.....
    You are correct. Many use some sort of 2 stroke oil that does. Most 2 stroke oils do not mix well either.
    Castor "R" Its like a drug for the real motor head.
    I remember when Indy smelled of the stuff even outside the raceway. You could drive in front of Ascot raceway and smell it for blocks.
    Every racing 2 stroke , sprite car, and champ car in the world was running on the stuff.
    Klots (bean oil) was my preferred....
    I hear a couple tablespoons of Marvel in your Cheerios keeps you regular...
    Nov 2008
    Orangevale CA
    Let Me know how that works out for YOU Bud .... E
    Member Kurtis502's Avatar
    Oakdale Ca.
    Default Marvel Mystery Oil
    I been using it for years to lube my fuel system after draining the alcohol. Pour it in the fuel pump and push out all the alcohol, lubes the o-rings. Wouldn't use anything else. Never seen any wear in my fuel pump.
