Motor problems please help
Results 1 to 14 of 21
    anaheim hills ca
    Default Motor problems please help
    ok so i just bought a 1981 miller and the boat is beautiful, i took it out for the first time this weekend, it has a 512 bbf in it, i had to adjust the idle and the water intake and thats about it, except one thing when i come into the 5mph zone and start to idle there is a skreaching sound coming from the motor, i cant put my finger on it so lets hear some ideas, only at idle there is a skreaching noise.......
    Does it do it out of water with motor running? Sounds like a pump bearing.
    If you are 100% sure it is coming from the motor, the last time I heard that, it was a spun main. I have soun rod bearings and didn't know it till it was torn down. But a main will tell you like right now.
    Hate to say this, but there really isn't much in a motor that skreeches.
    Maybe something in the flex plate. Starter that didn't disengage can make a pretty ugly sound. Does it restart OK.
    A spun main is a bitch to crank over. Does it start right back up?
    Nov 2008
    Orangevale CA
    I had a carb base gasket make a terrible whistle once when it was leaking (only at Idle) , ..... E
    [QUOTE=J Shelfo; My all time favorite quote; Flatbottoms are like shopping carts, every once in a while, you get a good one.....
    anaheim hills ca
    starts up with no problem, were would I check the pump because when I put into reverse it will stop screaching its almost like when I put a load on it it stops, and yes I have only run it in the water, and it only happenes when im coming in if I put the boat in the water and idle out its ok but when I come back in it starts skreaching on and off. Hmmmmmm 714 781 9389
    Placentia, CA
    Alternater belt loose?
    steveo143 AKA DiMarco 21 II
    Senior Member TexasJet's Avatar
    College Station, Texas
    The OD of your impeller may be brushing against the ID of you bowl. Pull the bowl and look for signs of wear on the inside "shoulder" ( I don't know what else to call it ) of the bowl. If you have an aluminum impeller you may see signs of wear on the outside shoulder of the impeller.
    I had a similar noise I swore was coming from the engine. It turned out to be what I described above. I ground a little off the ID of the bowl and the scraping noise went away.
    Oh hell. Nobody said this was a squirt gun. The BBF should have been a dead give away. Never mind
    anaheim hills ca
    It said it in my first post, wats the give away, and motors are motors.
    anaheim hills ca
    Quote Originally Posted by steveo143 View Post
    I took the.belt off and noise is still there
    058
    058 is offline
    Quote Originally Posted by jmcracing118 View Post
    Disconnect the driveshaft, restart engine. Does it still screech? How is the oil pressure? Any main bearing bad enough to hear any sort of noise will lose oil pressure. IMO I think it is in the pump, a shaft bearing or as posed above the impeller rubbing the housing....but wtf do I know, I'm a prop guy.
    Just re-read, no mention of a jet. No matter.
    you can pretty much assume its a jet due to the Ford because I can count all the Ford v-drives I have seen(that were build in the past 30 years) on one hand, and they all belong to 058
    In the 60s, Ford v drives were all you saw
    Quote Originally Posted by 058 View Post
    Had a 352 crank in a 428 block the rotated at about 8500. Never lost oil pressure. Probaly due to the fact it simply shut the oil off to that main and two rods. Damn thing could have wakened the dead though. Thought it was a fan belt till I let off and the engine locked.
    I agree. Remove the drive shaft and run it. Chances are its the pump. But then, I don't crap about jets. Never owned one, never even riden in one.
    anaheim hills ca
    Cool thanks guys for all the help I will disconect the output as soon as I get home tonight
    Thanks again
    Senior Member nick's Avatar
    Fullerton & Water Wheel Resort
    I would also look into the carb, scoop, arrestors.... reason i say that is because if there is a minor air leak around one of those items the air being pulled in could be causing the sound you are hearing.
    I know when i'm idling in my boat the air being pulled in thru my spark arrestor whistles a bit, when it first happend i had no clue what it was...
    Just an idea.
    OH yeah and weren't you the guy that posted up looking for "an 80 MPH jet boat"? What did you end up getting? Tell us more.
