Unchained !!!!How does e-98 without intercooler compare to e-85 with the intercooler
Results 1 to 14 of 19
    Senior Member badbug3's Avatar
    Default Unchained !!!!How does e-98 without intercooler compare to e-85 with the intercooler
    I was wondering if you would share your findings on the comparisons between the performance capabilities between the e85 intercooled setup and the non intercooled e98. Do you know what the inlet temps are on the two at around 25 lbs boost? Meaning temps of the air before throttle body, not before going into cylinder. Which is the safer of the two as far as detonation and preignition goes. Also how much boost do you think you can run with e-98 without the intercooler?
    Ada, Michigan
    Quote Originally Posted by badbug3 View Post
    Well my E98 source decided that he was only going to make E50 to inject into diesels so that source is not available to me. It's a couple hour drive to the next available E98 source in Bay City. I have just been running E85 so far this year.
    The changes I made over this winter were,
    Removed the intercooler and that reclaimed at least 2# of boost.
    Changed connecting rods and that increased compression to 9.3:1 (long story there)
    Changed to 225# Atomizer injectors.
    The first time I took it out it was a monster far beyond the previous package. Downright dangerous. I bet it was over 2k HP. It flashed to 30# boost in a split second. I have a video I didn't intend on showing but I will anyways .... laugh it up,
    Here's WOT for 2 1/2 seconds looking out the back,
    may11test1.mp4 video by Mark11530 - Photobucket I never had the bow just keep climbing like that, usually it leveled off about 85 mph.
    A couple days ago I came up with an easy method to control the boost that has worked good so I got it down around 20# now.
    The IAT at 30# boost was 229 degrees and I didn't think that was too bad for no intercooler. With Ethanol I don't think it ever needed the intercooler in the first place.
    Another run I datalogged yesterday at 21# boost showed the IAT at 201 degrees. Of course that's upstream of the injectors so I have no good way to tell what it is after the fuel vaporizes.
    It's hard to explain to someone the amount of torque a package like this put's out.
    Hass knows now.
    Senior Member stallion176's Avatar
    bad ass... hoping to have my setup rolling in few weeks. I bought Hass old setup and converted it to blow thru. 9.5:1 496 with 15 lbs intercooled with a csu 1050 with EV Pro hat all in my tx-20. i hope it does ok... well see..
    Unchained, I would love to be the very first person to tell you that you are insane. But I am certain you have already been told that.
    Having the IAT 200+ before the injectors is not very telling. And even with a thermocouple probe after the injectors, it won't tell you much. At the velcocity things are going in the port, only part of the heat absorbtion has taken place. But it continues thru the entire intake event, until you start compressing, and some may actually still be taking place. Bottom line is, if it doesn't rattle. Although there is some octane inprovement in the 98 over the 85, simply because the gas is the crutch of both, I doubt there is a huge BTU absorbtion diff between the two. We both know, you would take 25* additional IAT if you could gain the octain difference between the two. Sadly, the 98 could give you both.
    Have to tell you Unchained, if I was going to built a motor for my GN for lake play use, you built the recipe right there. That thing is bad ass. But I think Hass and Info are trying to dethrone you.
    And all 3 of you are going to get taken down by 16 year old with a wrecking yard LS with John Deere turbos and a 1000 HP fogger
    Somewhere between Paso & L.A.
    Damn your boat looks fun, Mark!!
    Mark it looked as if the prop walked a little, just before you let out of it. Impressive!!
    Ada, Michigan
    Yeah there's a list of people who just won't ride in the boat with me driving and I'm about to add myself to the list.
    Thanks Bob,
    I think Hass is a bit overwhelmed by what he created at this point.
    I give him until the end of the season then he'll turn it up to 28# - 30# and get the full effect.
    Ron's project on methanol is going to have some huge potential especially with the larger turbo's he got.
    Either one of those jet's would hole shot me something fierce from a dead stop.
    Hitting it from 30 mph like a lake race would be interesting though.
    I want to see those guys race each other.
    okie, lake Texoma
    Thanks Bob,
    I'm sure that will go down
    I must have him worried though, since the challenge he's stepped up to an aluminum engine with more cubes than mine with the trick heads, stepped up to the larger turbos, hell next thing you know he'll be going to a blow through carb too
    In all seriousness though , I dont think Ron realises just what an animal he's assembling there. What it will really all comes down to is who has the balls to run the most boost. They might just have me there (might)
    H8-2-W8
    [email protected] first pass
    Senior Member Here Comes Whitey's Avatar
    Budweiser rd hit squad
    Hass knows now.
    Do you have a down pedal?
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    LMAO I think he has a pedal. If it's anything like mine was, it's pretty much ineffective.
    Yea I'm continually chasing Hass. lol He has cost us a lot of $$ this year.
    And also everyone has their opinion of a monster. I have had a monster or two to compare it with. Can't hardly wait to get it going.
    Pretty impressive leap Mark. From an engine no taller than the back seat.
    QE 439 Twin Turbo
    Ada, Michigan
    Quote Originally Posted by Here Comes Whitey View Post
    Yeah I have one, when I tried to use it before instead of holding the bow down it wanted to jack the stern up and walk on the prop which was much scarier. In other words, ...... I don't know how to use the down pedal properly.
    It keeps the bow down much better with the two blade prop but it vibrates more then the three blade so I don't use it as often.
    Ron, you hit the nail on the head with, "everyone has their opinion of a monster"
    Here are things I have had happen in the Jeff Foxworthy format,
    1) When you get out of the boat if you're shaking, It was a monster.
    2) If people refuse to ride with you, it was a monster.
    3) If you have to look in the mirror and give yourself a stern talking to before you take the boat out, it's a monster.
    4) If you can't look at ANY gauges during the whole run....it was a monster.
    5) If one of your friends isn't going to let you get back in the boat to make another run,
    it was a monster.
    add your own......
    deckboat owner rschap1's Avatar
    Lowell MI
    Default COOL vid!
    That didn't look like Murray Lake and I don't recall seeing or hearing that rocket launch here
    Congrats
    Looks like on HE-- of a ride! ! !
    Sounded like it too.
    okie, lake Texoma
    Your going to find that those other things you've had were mere toys compared to this animal. I'll be the first to say I told you so! (Oh thats right, I think Mark may have beat me to the punch on that one,lol)
    H8-2-W8
    Green Bay Wi,USA
    How did you manage to regulate the boost down to 20lbs?
