Best Jets to Run
Results 1 to 2 of 2
Best Jets to Run
    Senior Member Swain's Avatar
    Aug 2009
    Default Best Jets to Run
    I have a stock 502 that i just put a Barry Grant Mighty Demon 850.
    Only thing I have done to the engine was put Eddie Marine Exhaust on it.
    What size jets would work best? I read 82 P 88 S
    Any input would be helpful.
    Jason
    Default Return the BG 850
    I should charge you for this because it cost me $950 for the dyno to find out
    I have a new 540 Dart motor I put on the dyno for a day with a BG Marine 850 mighty demon. we broke the motor in but couldn't get the carb right - see utube 540 - anyway
    too rich in low RPM to lean high - found the boosters were too small and only Barry Grant could fix ( the jetting couldn't fix the problem because the boosters were too small) only issue Barry Grant went out of business the day we we were on the Dyno. Jeg's came to the rescue and traded my BG for an 850 Holley marine. My BG 850 was a down leg mech secondary carb - beautiful compared to the Holley but crap as a carb.
