Belt drive fuel pump question
Results 1 to 14 of 18
    Bouncing off rocks TryMe's Avatar
    Sep 2008
    St Louis
    Default Belt drive fuel pump question
    I have a 6.0LS in my jet boat that has a belly tank. Ive tried several different electric fuel pumps with varying degrees of success. The electrics work fine when primed, but they are a real pain to get primed if you run out of/low on gas or if the boat has sat for more than a day. When I ran SBC or BBC w/ mechanical pump in this boat I never had a problem.
    So my question is: will a belt drive fuel pump like aeromotive 17140 draw fuel from below as well as a standard mechanical diaphragm pump? Are there any pitfalls to running a belt driven fuel pump? I would really hate to drop $500 and still have the same problems. Any better ideas?
    Kingman/Golden Vly, Az
    my .02 cents...K.I.S.S....go back to what worked for you before & save the $$$ on something you really dont need! ...just sayin'
    FastRat
    Lake Havasu az.
    Just guessing here but i don't think ls motor comes with a mechanical pump, or a place to bolt it to or a lobe on the cam.
    Sheriff Joe Arpaio
    Placentia, CA
    How about an in tank electric like the cars use, might be a whole lot cheaper? What is the tank made of?
    steveo143 AKA DiMarco 21 II
    Tower Park Resort, Lodi, CA
    Quote Originally Posted by TryMe View Post
    Quote Originally Posted by Sold honda.bought hondo View Post
    I forget who did it, there was a thread a long while back about this. Some electric pumps are fully submersible. Mounting one inside the fuel cell will certainly solve any priming issues... I would assume.
    Example: Aeromotive A1000 FUEL PUMP
    Senior Member slow67's Avatar
    DFW
    From what I understand, belt drive pumps pull really well as long as their primed. Many drag cars run a rear fuel tank down to 1.2 60'. Biggest problem with them is the cold start, where many people add an electric just for that purpose. Some have also added check valves with varying degrees of success.
    SoCal
    You will only have to spend your money once with a belt setup. A belt pump will tell you when its getting tired, a electric pump will just go out most of the time if lucky or if un lucky it will brown out and go lean.
    waterloo
    When I ran my river runner on blown gas carbs, I used the exact setup.
    I actually pressed a gilmer pulley on the jet ... u joint holder thing... wtf is that called? YOLK... is that it? Then made a bracket that clamped around my jet pmp. The pump holder bolted to this bracket. Belt, bingo. I used a mechanical regulator with a return to the tank.
    Worked without fail.
    BTW, I'm sure this is bad (spamming or something) but I have a pump, and belt drive adapter I'd make a smokin deal on.
    Wags
    Sep 2008
    St Louis
    there is no mechanical pump provision on an LS . Its an aluminum tank, slight v in it that matches the hull and flat across the top. Only about 7 inches deep in the middle. I hadnt really considered in tank mounting. So i guess a belt drive wouldnt self prime either? Thats pretty much the problem i already have
    wags, sending you a pm
    waterloo
    You need to mount a belt drive pump low. That is why I put mine on the jet itself. That was below fuel tank level.
    Wags
    cfm
    cfm is offline
    You weren't using a fine micron filter before the pumps that failed were you ?
    Where do you have the return line terminating ?
    Do you have a section of line from the pick-up tube that is higher than the fuel pump ?
    Have you checked your vent for blockage or incorrect sizing ?
    SoCal
    The mechanical belt pump will self prime.
    Somewhere between Paso & L.A.
    check out the other thread here by Unchained today..... put a submersable electric pump
    in your tank, and forget about it. (he makes around 2000hp, so it should work fine for you
    too)
    DFW
    Quote Originally Posted by motormonkey View Post
    Only if the fuel lines and pump are below the fuel cell
