Rotating Assembly
Rotating Assembly
    Senior Member Cobra 02's Avatar
    Montclair
    Default Rotating Assembly
    Going to build a BBC 496, witch rotating Assembly is Better Eagle or Scat.
    Going in a heavy ass jet boat, with AFR 305 heads....
    Eagle Specialty Products B11113060 - Eagle Competition Rotating Assemblies - Overview - SummitRacing.com
    or
    SCAT Engine Components 1-42360-60 - Scat Engine Rotating Assemblies - Overview - SummitRacing.com
    Thanks for any input you may have.
    Redding, CA
    Quote Originally Posted by Cobra 02 View Post
    or
    I used an Eagle kit with .030 pistons and stock stroke. It has the good capscrew rods and neutral balance Crank. Not sure what your' kit has there, but I got it through my machine shop for about $300.00 cheaper than Summit offered it. (I paid around $1650.00 as I recall)
    They did have to rebalance everything and "tune" up the rods and Crank for clearances, but thats mandatory anyway in my book.
    Been running great for 1 1/2 seasons.
    Most of the guys on here seem to prefer Scat.
    Next time when I stroke it I'll probably go Scat, or piece it out with better stuff.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Somewhere between Paso & L.A.
    like said- I prefer SCAT, but I have seen "blem" type stuff come from both- make sure
    you have the stuff checked out whether scat or eagle.....
    sacramento
    or
    scat is the sh!tcouldn't resist. i used a scat crank & it cracked after motor failed (hammered the mains completely out , bearing meterial blocked the oil passage)but ran fine for a long timebefore that. i believe i egged out some eagle rods on a 460 fairly stock motor so i would not buy eagle stuff again.i bought a callies this last time.
