figureing new pushrod length with t&d's
Results 1 to 13 of 13
    sacramento
    Default figureing new pushrod length with t&d's
    the length for these were very touchy to figure out so i cut one pushrod & put fuel line over it so i could adjust it to the right length for both the intake & exaust.
ID:	116915   Click image for larger version.
ID:	116916   Click image for larger version.
    okie, lake Texoma
    Quote Originally Posted by turbo wog View Post
    You using the little setup guage that comes with the T&D's ?
    H8-2-W8
    [email protected] first pass
    Yep,, based on your other thread, make sure you have the stands set up correctly before you try to figure pushrod length. Depending on valve length, you may need the heads or rocker stands machined (like the set of Brodix that I am currently setting up with T&D rockers)
    PS,, clever thinking with the fuel line, since the actual geometry is determined by the rocker stands.
    sacramento
    i did at the race shop on the counter & they said not to use it & set it up not shiming it!it looked better on the valve that way. i will take it back in to double check now that it is all together .
    sacramento
    i think i screwed up !? i might shim the rockers up gonna take it back to the race shop first.
    Placentia, CA
    Paulie, what shop are you using? Take them to Dee Reily's and get them done right! Hope you have some inconel or super alloys for the exhaust.
    steveo143 AKA DiMarco 21 II
    sacramento
    Quote Originally Posted by steveo143 View Post
    who is Dee Reily & where is he located. ,yes i am running the feria valves
    Placentia, CA
    He is in Yuba City, probably the best engine guy in Nor. Cal. Call LSR for info, Andy could tell you but he is in Oregon and doesn't know how to use his new phone!
    Placentia, CA
    Shop is called 'Built by Dee'
    sacramento
    thanks, is he a head guy or a motor guy ?
    sacramento
    i think i might have some cool tent stakes to bring to the lake if any one needs 16 of themthey look just like .210 pushrods!
    Placentia, CA
    One stop shop, he's and old fart like me, ex boat racer, over the top fabricator. His son Cory runs the day to day operation. In house engine dyno etc. Do you have the correct length valves in those heads?
    sacramento
    yes i have had them set up from the shop & i have had them since 2005 in my motor.
