Holley booster install????
Results 1 to 5 of 5
    Redding, CA
    Default Holley booster install????
    A couple of the boosters are loose on my 6109 bodies.
    (I can move them slightly by hand)
    Is there an easy fix or do they need re-installed?
    Any one around Sac or Chico etc. on here that can do it?
    Are most carb shops set up to do it??
    Thanks!!
    (I have those $90.00 red billet plates ordered and a bunch of re-build stuff on order from the joint in NY.)
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Sep 2010
    There are tools available that can fix that. I looked at the pictures of one on line and made one. I am not sure how many shops have the tool. You might get lucky asking around in your area.
    Gary
    Redding, CA
    Quote Originally Posted by HPbyGD View Post
    Gary
    Thanks Gary!
    I looked at the tools, but since these are probably the only carbs I'll ever really get into this deep, I really can't justify buying the tool. (making one is out of the question for me!)
    Maybe some one on here in Nor-Cal will help me out.
    If not I'll be back home in a couple weeks and will ask the local shops.
    Tommy
    058 is offline
    If they aren't too loose, like ready to fall out loose try a little red Lock-Tite. I've done several with good results. When you add a drop of L/T wiggle the booster just a little bit to work it in and let it set up. I have also used a small hammer and a center punch to slightly peen the flange over.
    Redding, CA
    Quote Originally Posted by 058 View Post
    Thats kind of what I was thinking. You can just barely wiggle them.
    Tommy
