Twin Turbo Draw Thru Fuel System
Results 1 to 8 of 8
    Apr 2009
    Default Twin Turbo Draw Thru Fuel System
    Was wondering if an Edelbrock Victor Jr mechanical fuel pump would be enough for this system on 10 pounds of boost. Also, can you dead head it with regulates up by the carb? Bought a previousely owned 468 BBC Gail banks with dual Holley 750's that was set up this way but I just don't see it working. There is a fuel block on the the rear of the the engine with two one way check valves. One side is been feed by that mechanical and the other, well, had a short #8 hose coming off like it was hooked to an electric pump, perhaps. I called him and he told me it was the return. But it each port has a one way check valve going into the dist block so it couldnt possibly be a return?? Also, he tapped the holley regulators mounting bolt hole to 1/8 in pipe. They had nice blue anodized 90 degree fittings with no hoses?? I thought they went to manifold for boost reference but it goes right into the fuel. Can't imagine returning fuel from way up there?? Possibly missing hoses with gauges?? It was supposely running fine when he took it out 6 months ago but??
    okie, lake Texoma
    Quote Originally Posted by jonnwald View Post
    That sounds like kind of a mixed up system you have there. I used one of these when I had my drawthrough deal and it was great. It takes a deadhead style regulator and doesnt require a return. I used a Magnafuel Reg. #MP-9633 because its what I had laying around and it worked great. But the Racepumps Regs work well too. The pump puts out a constant 50psi so it takes a good reg.
    Race Pumps Fuel Systems
    Stepped up to their EFI version and its feeding my blowthrough today. Its still the same pump, its just cranked up to 150psi outlet pressure.
    H8-2-W8
    [email protected] first pass
    Senior Member cheyenne580's Avatar
    Hass828 i don't mean to change the post but i'm thinking about putting a boost limiter on my PSI blower manifold to reduce the boost.Do you know anything about these?Or would it be better to go with BOV.I'm trying to use my blower for the race track and river use.The blower has a 23lb cut in which would not be good for idling at the river.There is a easy fix but if i do it then the blower will not make the boost for the race track.This easy fix is to open up the bottom of the blower case to a 6lb cut.In turn it takes 6lbs away from the blower.Any ideas would help.Remember this is for two different motor's that i have.Lake and Race.
    okie, lake Texoma
    Quote Originally Posted by cheyenne580 View Post
    Thats greek to me, dont know anything about'em, sorry.
    H8-2-W8
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Why not just change pulleys?
    Would a BOV blow out air and fuel?
    QE 439 Twin Turbo
    cfm
    cfm is offline
    It's a draw thru so the boost means nothing if your asking about fuel psi differential. IE: you won't be boost referencing the pump nor regulator.
    Only thing you'll need to know how much hp your engine is making to determine if that fuel pump can supply enough volume.
    Senior Member slow67's Avatar
    DFW
    Don't use BOV on a draw thru....no need. There is no throttle blade for boost to back up against.
    Douglas, MA
    Are you sure he didn't just have the electric pump backing up the mechanical?
    pics usually help on this stuff.
