Size of Pipe for hole over oil filter BBC
Results 1 to 5 of 5
    May 2010
    Discovery Bay, CA
    Default Size of Pipe for hole over oil filter BBC
    Anyone know the size of the hole over the oil filter on the side of a BBC where the oil pressure sender attaches Not sure if it is 3/8 pipe or 1/2 pipe I need to order fittings
    THANK YOU
    Break Out AnotherThousand
    Somewhere between Paso & L.A.
    older 4 bolts are 1/2" npt, most 2 bolts are 3/8npt, could be either, not knowing what block you have you better just go look
    Mohave Valley/Quartzsite
    If I'm remembering correctly my bowtie has a 1/2" and a 3/8" pipe.. I'll have to check and verify that.
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
    Quote Originally Posted by stix818 View Post
    wish I had a bowtie.........
    May 2010
    Discovery Bay, CA
    Thanks guys did some meassuring looks like it is 3/8 pipe
