Something to argue about...
Results 1 to 8 of 8
    waterloo
    Default Something to argue about...
    OK, for all you blown, injected guys. Long story, but wtf.
    Last Saturday a guy (the seized guide engine guy) came into the motor home I was cooling off in. (after trying to stroke out). He said he needed a spark plug wire. I asked why. He said he had a dead cylinder. 1 cyl was puking out raw alcohol. He had changed plugs, adjusted valves, checked timing, and went over everything 2 times. He said the wire was the only thing left, but it shocked him. I told him if it shocked him it will fire a plug.
    I told him to level his boat and everything would be fine. He just thought I was delerious. His boat was backed up a hill slightly. Not huge by any means, but ass up. He said not to worry about it? I said, no, just start it, watch it puke out alky, drive forward and it will stop. Well, after my best boat racing buddy told me to quit screwing with him I explained I had gone through the same thing once.
    I had my boat backed down a hill slightly. Warmed it up and puking alky out of 1 cyl. Same thing, cap, rotor, valve lash, port nozzle, etc. It was raw alky. After checking everything, swapping plugs, wires with one I knew was firing, etc I pulled it forward. Problem solved.
    Explain it.
    On paper it cannot happen.
    On a hill it can.
    Has anyone ever seen this?
    My buddy who has been around 40+ years in racing said he thought I was full of shit. I would not have believed it if I had not gone through it.
    Wags
    Gone
    Sparks, Nevada
    Well I have never seen that. They say blowers screw the fuel to the front tho.
    Senior Member lbhsbz's Avatar
    Long Beach
    Gravity.
    With low enough air volume moving through the intake it makes sense...especially with alky.....I would think it should recover at higher rpms though....
    waterloo
    I don't remember if he brought up rpm's. I also don't remember if I did. It was years ago for me. I cold not help but laugh. He thought I was jerking his chain, 1/2 hour later he thought I was a genius.
    Wags
    Gone
    Sparks, Nevada
    And then you beat the guy and sent him home early.
    Now thats some funny shit right there
    Couldn't be gravity. Gravity sucks, and that would only help the situation
    Dec 2010
    Sapulpa ok
    My Buddy James had the same problem 14-71 full open std. helix hydro broke the starter more than once went to port nozzles end of problem. When it wasnt hitched to the truck nose down it was #7 or 8 then if it was down hill slightly hitch to the truck it was #1 or 2 It was rich as hell though. Hydraulics can help or hurt
    waterloo
    Craig, this guys piece is pretty fat also. He always has crappy looking oil.
    I can't remember if I was running a 2 speed when my issue popped up or not. With the 2 speed the engine was always fat (not milky oil fat) to take power out.
    Wags
