Does anyone know if there is a Gen 5, hyd cam that matchs up close with this mech cam? TIA
CRANE 131311
Part Number: 131311 Grind Number: F-256/3634-2S-8
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1967 Up CHEVROLET 8 PERFORMANCE USAGE, GOOD MID AND UPPER RPM TORQUE AND HP, BRACKET RACING, AUTO TRANS W/RACE CONVERTER, 11.5 TO 12.5 COMPRESSION RATIO ADVISED. BASIC RPM 4200-7200
Engine Size Configuration
396-454 C.I. V
Valve Setting: Intake .026 Exhaust .026 HOT
Lift: Intake @Cam 3634 @Valve 618 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 3754 @Valve 638
Rocker Arm Ratio 1.7
Cam Timing: TAPPET @.020
Lift: Opens Closes ADV Duration
Intake 38 BTDC 74 ABDC 292 °
Exhaust 78 BBDC 42 ATDC 300 °
Spring Requirements: Triple Dual Outer Inner
Part Number 99896
Loads Closed 132 LBS @ 1.906 or 1 29/32
Open 405 LBS @ 1.326
Recommended RPM range with matching components
Minimum RPM 4200
Maximum RPM 7000
Valve Float 7400
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 23 BTDC 53 ABDC 105 256 °
Exhaust 63 BBDC 21 ATDC 111 264 °
