Firing a new Engine
Results 1 to 14 of 24
Firing a new Engine
    Las Vegas, Nv
    Default Firing a new Engine
    Well the time has finnaly come and I am ready to fire up the new engine.
    The engine has been pimed with oil and is ready to go. My question though is, the fuel system is dry and the oil cooler system lines are dry with the exception of the oil filters,I am running a mechanical fuel pump, should the fuel system be primed and should the oil cooler lines be filled and if so how should it be done? Should I pre fill the fuel filter?....Thanks....Hal
    The Man cordog009's Avatar
    East Texas
    Your oil cooler lines will be filled shortly after the engine starts spinning over. Just go back and check the oil level after you get it fired since some oil is now gonna be filling the hoses and cooler. I'd fill the fuel filter if it's a style that allows you to easily pre-fill it.
    1984 Youngblood TX-19 SOLD
    Mohave Valley/Quartzsite
    For easy starting I typically fill the float bowls through the vent tubes.. Cut a beer can in half and add fuel.. Once that is done push on all the accelerator pumps until fuel comes out.. Once it's running everything should prime..
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
    Oct 2010
    Lake Dallas TX
    lol yeah all that and put the dizzy in the right way ... 180 out on a first fire sux nads ....
    Why are the oil lines and cooler filled from the priming. did you prime this on a stand? I like prime it as an assembly. That way any leaks that may pop will get got before I fire the engine.
    stix is right. Prime the carb my filling the bowls. Never crank an engine till you have fuel. Once the engine fires, fuel will be at the carbs long before the carbs run out. No, you don't need to prime the fuel filter.
    Senior Member bp298's Avatar
    LHC
    Why are the oil lines and cooler not filled from the priming. did you prime this on a stand? I like prime it as an assembly. That way any leaks that may pop will get got before I fire the engine.
    fixed it for ya. seemed odd to me too. prime the entire oil system, not just part of it.
    Mar 2011
    I'd be interested in hearing thoughts / opinions on cam break in on a new build -thanks moose
    Quote Originally Posted by daMoose View Post
    What cam??? Is it a roller or flat or maybe a hydraulic? For what its worth I do not know how long it has been sitting or if the feul system has been touched. If it were me I would grab an electric pump and flush the feul system prior to firing. Nothing worse than sending a bunch of nasties into a carb during initial fire-up. You know, the old float stuck vac passages getting plugged, that whole bag of bummers! M
    Las Vegas, Nv
    The oil cooler and lines are mounted in the boat. It is not a block mounted oil cooler.
    Las Vegas, Nv
    It is a full roller engine and all fuel lines are brand new.
    So is mine. All the more reason to test everything as an assembly. Connect everything, and then prime the engine. That way you not only priming everything, your also checking everything for leaks
    rollers really don't require a break-in, but I would and do keep the "R"s up for a few minutes just to get the splash on the spinning mass and up top for the valve-train. M
    Las Vegas, Nv
    gn7 ,I think I understand what you are saying now,put the engine in the boat and conect every thing and then prime the whole system.
    What about water ,as there is no water pump or Tstat and I do not have the jet pump in, I have made a hose adapter to conect to the water fitting on the transom plate. Is there a certain amount of presure to push the water thru the engine that I should be carefull with? I am set up with two dumps out the back....H
    Just open the tap 1/4 to 1/2 turn to start. You don't want to put alot of pressure in the block and heads. Wait till the water starts coming out the dumps, and light it off. It doesn't take alot of water sitting in your drive way. Your just not maiking that much heat. If the water dump gets hotter than you can hold your hand under, turn the water up ALITTLE.
