Proper way to gap spark plugs
Results 1 to 14 of 27
    waterloo
    Default Proper way to gap spark plugs
    I figure this ought to be fun.
    What is the proper way to gap spark plugs? Do you use the screwdriver and hammer on the fender method? Feeler gauges, or the round wire gauges? Or the single round disc piece of crap. Does it really matter? (to mag guys if course it does cause they hardly spark)
    Do you use the:
    1) Screwdriver and hammer method. ROFL (I ususally do this with the round wire gauges IF I bother to check em on my piece)
    2) The old tool that was made by jacobs maybe? Feeler gauge and pushed on ground strap? (used to use this piece all the time)
    3) One of the fancy screw down gappers that seem to be the rage now a days? (never even touched one)
    4) Or say F it. Its a boat. (mostly this with my boat)
    Wags
    Atlanta, Texas, United States
    Don't they come out of the box gapped?
    Just kidding. I use an old Champion spark plug tool I have had for over twenty years. It has wire gages and a tool that slips over the strap to bend it to the proper gap. I once used the Jacobs tool for awhile with reasonable results.
    WAGS!!!
    Only guys with mags split hairs like this. And thats only because they need the split hair for a feeler gauge
    I was warned about gapping plugs because you don't want to bend the ground strap if you can avoid it.
    And I thought I was anal....
    Don't let that one comment that someone made make you think you are any less anal. You aren't
    Default Yeah....
    Yeah it's a pain in the ass to gap the tight numbers for a mag, but once every 10 or 15 years isn't too much trouble... After all, there are only 8 per motor, per decade, right?....
    Ray
    LOUD BOATS SAVE LIVES
    Just Me snoc653's Avatar
    Eastern Iowa
    Ray
    Ray, I think you may be putting the plugs in the wrong place while you try to adjust the gap. Try using the champion spark plug gapper that gearhead mentioned. It would be a lot easier than trying to get the KY off the plugs after you gap them.
    Personally, I use a Champion gap gauge set as well.
    okie, lake Texoma
    Do you use the:
    Wags
    I would think that you guys with the super duper - mega powerful- atom splitting- electronics would just cut the strap off and not mess with it. Its just in the way of that huge spark that is being produced.
    As for me I also use the tool that Gearhead mentioned from champion. Never had an issue.
    (Dont be so jealous of us mag guys and the fact that mags are still the strongest ignition system out there, keep saving and you can get one some day )
    H8-2-W8
    [email protected] first pass
    Senior Member fireboat607's Avatar
    Nampa, Idaho
    Put the spark plug socket in a drill press vise, put it up on the thirty ton hydralic press, throw in a plug, turn on the power, press down on the strap until the proper gap is achieved, takes time but it works. The plug for #1 cylinder gets a little more gap because it fires first, then it tightens up down the firing order.
    Anyone can pedal a bicycle can you pedal a flat?????
    Default Mag advantage
    See, that's an advantage exclusive to the mags, you don't have to worry about a little KY because the gap is so tight it'll still jump it...... At .018 I usually wind up using a feeler gage, but it is required so seldom it is not a problem... Those are the great races, the ones where you don't even pull a plug the entire weekend...
    Ray
    SoCal
    All you guys are wrong.
    Take needle nose pliers and bend the ground strap out as far as it will go. Install plugs in heads, set heads on motor with a few bolts. Now just turn motor over (counter clockwise, very important on this step) and they will gap themselves.
    Thanks Pops.
    waterloo
    WOW! This thread has provided me more entertainment than I had even imagined. You guys are some funny fellows.
    I especially like the drawing about splitting hairs, using those hairs for a gap gauge for mag plugs, and the pregapped and replace every few years. Funny stuff!
    Now, for the real queestion... what is the proper gap for a mag (.002)(if it is a "good" one) and an MSD (.160)
    Wags
    Wags, its all in good fun. But don't misunderstand the Ray and his changing plugs once a decade. He is so tight, the oil in his motor was poured in from one of the containers made of cardboard with the tin caps on each end that required you to stab the spout in, Except Ray to cheap to have a spout, and just stabs a couple holes with a screwdriver, and a funnel made of newspaper. What Ray didn't tell you is, is races once a decade, and is still on the first drum of fuel he ever bought.
