msd 6m2 tach issues
Results 1 to 6 of 6
msd 6m2 tach issues
    Apr 2010
    Default msd 6m2 tach issues
    i have a msd 6M2 on my small block powered sun runner. my tach is telling me im runnin in excess of 8K. i remember something about needing some sort of "filter" that goes in line between the msd box and the tach to bring the rpm read out down to where it actually is. any of this sound right ?
    Jul 2010
    Lubbock, TX
    Are you sure your tach doesn't have any "settings" on the back of it?
    What tach do you have? Maybe a quick download of the instructions can fix it without buying anything...
    "No, my boat doesn't need any more power" - No one ever
    With the MSD box the tach, the pick-up has to be re-moved, from the the coil, and hooked to the tach out on the MSD box.
    Some tachs, specifically OEM tachs and dare I say it, cheap tachs, can't deal with the 12 v square wave output of a MSD box. If your tach worked before the MSD, and now its wacked, you MAY need one of these. It would help to know the manufacture of the tach. If it has no appearent name, and is original equipment, it most likely needs an adaptor.
    Are you triggering the MSD with a points dizzy? Did you remove a ballast resistor? Then you need this one.
    LINK: MSD tach adapter with ballast resistor removed
    If the old ignition had no ballaat resistor, then this one.
    LINK: MSD tach adapter with current resistive wire.
    If your using a MSD magnetic pickup dizzy, then this one.
    LINK: MSD tach adapter with MSD mag pickup
    If he hooked the tach to the coil like a stock induction ignition, his tack is probably toast now. Most tachs won't put up with a 400-500 volt input for long
    Apr 2010
    they are a brand new set of farah(sp?) gauges. never hooked up before. il have to check in the morning to ensure if its hooked up properly. i am very confident that it is.
    Most important thing to remeber is to NOT hook it up according the directionsIF the directions show hooking ANY wire to the coil. That wire goes to the MSD box tach hook up.
    Also, I am 99.99% cetain you will need a adaptor with a Farah tach
