Help with heads, lifters etc PLEASE
Results 1 to 10 of 10
    Under yo mommas bed jangles's Avatar
    Marana, Az
    Default Help with heads, lifters etc PLEASE
    I have the 990 style heads with non adjustable rocker studs. I want to run a Lunati # 00026 flat tappet hyd cam. What all do I need to buy to change this. I believe I'll need the 4514-16 Comp 3/8 to 7/16 studs, Procomp 2320 roller tip rockers (non self aligning) as I have guides, and a Lunati Bracket Master Cam kit , part number 00026CLT. Am I missing anything? Any help is deeply appreciated. TIA
    jangles
    "Thanking Obama for killing Bin Laden is like thanking Ronald McDonald for the hamburger.
    Thank the SEALS NOT the CLOWN.
    Official Member IttyBittyTittyCommitee
    http://newsbusters.org/
    Maybe some push rods, different valve covers, gaskets, oil change with some zink additive (Comp 159). Have somebody check out the springs. No more than 120lbs on the seat and 300-320 over the nose.
    Tri-Cities, TN
    Please don't use Pro Comp Rockers on a Marine build. You are asking for catastrophic issues.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    cfm
    cfm is offline
    X 1 million. And would like to add "Not for any build."
    I use the scorpion roller rockers and no issues so far. anybody have any comments + or - on them? M
    Somewhere between Paso & L.A.
    Please don't use Pro Comp ANYTHING on a Marine build. You are asking for catastrophic issues.
    There, I fixed it for you!
    I have a early set of them that broke most of the trunnions i sent them back to scorpion and they told me they were not there's, I bought them from a speed whse new and in the box. I was the jobber for them. rockers look new other then that.
    Marana, Az
    I bought what I think I need. Thanks for the help.
    Quote Originally Posted by havasubyou View Post
    WOW sure would like to see a pic of those! I must imagine you are running alot of spring pressure or have other issues? Not insulting just REALLY curious as to why? Mine are working fine after 2 years, but I run modest pressure and check for coil bind and rocker to stud clearance on assembly. M
    A couple of things caught my eye on this post. You say EARLY set, like as in 10-12 years ag? Because I would love to know how Scorpion could deny making them unless they were pretty old. Scorpion rockers are not hard to identify. Little kids can do it. Even before the Scorpion laser etching, they had a unique look to them. Be pretty hard to deny making them for sure. Unless of course, they weren't Scorpions
    If they were that early, I think they may have changed a little, and I would have no problem running them today. I know alot of people running them, and none have had problems.
