Looking for a Dominator Guru!
Results 1 to 14 of 14
    Southwest corner AR
    Default Looking for a Dominator Guru!
    I am looking for some help with a Holley Dominator! Any info to correct the problem I am having would be great! Phone nos. names, bussinesses!
    WT
    WFL Crew!!!
    Tri-Cities, TN
    I told you to call Lance Patton......678 984 0106
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Southwest corner AR
    You did? Well I will!
    WT
    WFL Crew!!!
    Or you can ask the guy that taught Lance everything he knows.
    Southwest corner AR
    And who would that be?
    WT
    WFL Crew!!!
    Senior Member Pattymelt18's Avatar
    Jon Moreland C&J engineering 562-229-0222. He will get you exactly where you want to be.
    so educate us whats the carb problem?
    Southwest corner AR
    A lean spot I am trying to destroy! Between Int. and high speed!
    WT
    WFL Crew!!!
    Try pulling the intermediate air bleeds, and see if that changes, for better or worse.
    Senior Member hotbo's Avatar
    lake Ouachita AR
    are these the Dommies on your new motor?
    if so i thought Pro=systems built them?
    WFLC
    2011 Performer SS
    built by Scott Seastrom.
    Senior Member 18GullwingMailman's Avatar
    Dec 2010
    Conway, AR
    Default Opposite
    Funny. My 1250 is fat right in mid-range!
    WFL Crew <----------> WFL Crew
    Quote Originally Posted by 18GullwingMailman View Post
    Thats pretty normal for a 3 circuit dom. I have to believe Widetrak isn't dealing with a stock Dom. Its either modified, or aftermarket. Never heard of a 3 circuit Dom going lean in the mid range. Assuming it is a 3 circuit based on his post, "between int, and high speed" If its a 2 circuit, not surprised one bit.
    Southwest corner AR
    I have talked to Jon at [email protected] and he is thinking that the linkage is the problem! The carbs are Pro Systems and I have had good luck with them in the past! But I haven't been able to get a return call back from Patrick in 5 messages!
    The lean spot that is showing up is around cruise range 2750- 3300 RPM range! So I have tryed different bleed sizes changed main jets ETC. It has a great idle and startup and runs good through the range but has a surging in the mid range!
    This weekend put in colder plugs and added mufflers helped some but exhaust gets way too hot! Plugs in the proper heat range will scare the crap out of you! Jet up mains and get upper stumble, and a poping in the 4000 RPM range!
    Im almost bald from stressing over this! I am closer but I like my stuff right!
    WT
    WFL Crew!!!
    Senior Member stoker2001's Avatar
    Folsom,Ca
    Thats odd,i have emailed Patrick on Sunday morning and got a reply the same dayand to top that off my sorry azz only spent $600 with him
    Whacker Smacker M/E #561 IHBA "first looser"champ 2006&2007&Sportsman Driver of the Year
