Cam retainer
Results 1 to 12 of 12
Cam retainer
    Under yo mommas bed jangles's Avatar
    Marana, Az
    Default Cam retainer
    Is this part necessay when using a hyd cam? There wasn't one on when I pulled the old cam out.
    TIA
    jangles
    "Thanking Obama for killing Bin Laden is like thanking Ronald McDonald for the hamburger.
    Thank the SEALS NOT the CLOWN.
    Official Member IttyBittyTittyCommitee
    http://newsbusters.org/
    No. it is not. BUTT. You will need a cam button for a jet or set cam end play with your waterpump if it is a V-Drive.
    Marana, Az
    It's a v-drive. How do I set cam end play? Is there a how to on here? I looked but didn't find any info.
    TIA
    jangles
    Quote Originally Posted by jangles View Post
    TIA
    jangles
    lets keep all this in perspective here. Jangles is a little tooooooo loose with his terms. Its not a roller.
    Marana, Az
    Why ya bustin my azz? I never said it was a roller...........
    Lake Havasu az.
    TIA
    jangles
    Well if you pulled out a hydraulic cam and it didn't have any method of
    cam retention, and nothing was trashed, and you put another hydraulic
    cam then you shouldn't need anything different.....although if it not roller
    it might be a good idea to buy 2.........they don't call them flat tappet for nothing....
    tap tap tap
    is the sound it makes when it goes
    flat flat flat
    Seems like the flat tappet is deal is on the way out....issues with oil additives and product quality make the extra money for a roller deal
    worth it.
    Cam goes flat one time, run all that shrapnel through the motor you just spent your last 10 or 1000 dollars to build will wreck your day.
    Roller is ready to run..no break in...you will need some kind of button on front and thrust washer/bearing on the back..it's not rocket science...
    A good set of rollers might be the last you ever need.
    But hey....if your just gona run an old stocker 454 out of a suburban
    run it
    Sheriff Joe Arpaio
    chill out jangles Never said you did. But you left it out and in todays world, people tend to think roller. Case in point, Evilforce's responses are roller related, and do not apply to flat tappet cams. Just jumped in so other didn't make the same assumtion. Nothing more.
    Marana, Az
    Okay, I'm chilled. Just got back from the 81s club house party. I'm a car motor boat dumbazz but it is finally ready to go back in...........Thanks
    Sold a honda bought a? Any ways you have lots of room to talk running an oooooollllldddddssssssmmmmooobbbiiiillleee.......
    Lake Havasu az.
    You makin fun of my olds???
    It's all good....the real funny part that with all things being equal, from idle speed to about 50 that olds motor will wax a full roller 427....Never gps'ed the olds but the numbers i get with the chev are lookin like the olds was running mid 80's...don't quote me on that but the olds will be back in the boat sometime this summer....
    And if you insist on running one of them 'might go flat at any time" tappet cams, break it in on and add to oil change a bottle of GM engine oil supplement.
    Close to 50 hrs. on the olds cam and it looks perfect.....even with 10/40 from wally world
    Sheriff Joe Arpaio
    Redding, CA
    That isn't the worst part... why he paints them pink I just don't understand....
    BUT, I do agree with him that all lifters should have wheels on them in today's' engines.
    I built literally hundreds of engines as a machinist back in the day with hyd. or solid cams.
    Wouldn't even think of it today.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Marana, Az
    Quote Originally Posted by Sold honda.bought hondo View Post
    Not really, just ribbin ya. I had a 67 442 back in the day and she was pretty damn quick til I wrecked it............They do need more after market go fast parts tho.....
    Maybe it's to match his pink Tou tuo...... This is a buget motor to see if I even like this boat. If I do I'll start another build and put this one in a cheap jet to unload the hull...
