what size prop do I need
    Feb 2011
    menifee
    Default what size prop do I need
    I bought a 22.5' kachina la bala has a bravo 1 with a 454 mpi motor and have no idea what prop to use it has no prop on it when I bought it, was stolen. any help is appreciated. looking for a good all around prop more on the mid to top end dont ski or tube at all
    PASO ROBLES CA cougar63's Avatar
    PASO ROBLES
    If the motor is in good shape and based on the fact your not gonna pull a skier,I would try a 24 pitch Bravo 4. Your 454 should pull it.You can find used ones for about $350 bucks . Good Luck
    Feb 2011
    menifee
    thanks will try that also what is the difference between bravo 1 props and brovo 3 ect
    Member bigmike58's Avatar
    Quote Originally Posted by tfutch View Post
    I have a prop that you can try out..I live just up the road from you. 951-926- six one six one, bigmike
    fyi..a bravo3 drive uses two props, counter rotating
    zombie you are seriously one screwed up dude. Good thing you decided to be on welfare for a living. Because you are way to stupid to have made it in the real world. GN7-
