Minimum octane for 14:1
Results 1 to 14 of 36
    Passin Glass HOOLI's Avatar
    In a state of confusion
    Question Minimum octane for 14:1
    What is the minimum octane required for 14:1? I'm told 110 and typically C-14 but others have told me that Av gas at 104 with boost juice will be fine. I'm having a hard time with 600+ a barrel of C-12- C-14 compared to 350 for av gas. It's a true 14:1 motor that is going to get detuned this winter to run pump gas ..but for the summer I need to find out the best fuel for the best price.
    jeff
    Anza, CA - Lost Lake, CA
    I don't have any problem with C-12 at that compression. I have also used Torco 110 and 112 with no problems. The engine lost power on the dyno with C-14, so 107-109 octane is fine with mine. Hope that helps. RR
    Cantard 71hallett's Avatar
    snow bank
    Not sure if you guys can get it but mark4 would be easier on your wallet and you would be fine with that.
    Senior Member hotbo's Avatar
    lake Ouachita AR
    Quote Originally Posted by HOOLI View Post
    jeff
    what heads
    cam size,duration lobe sep<ect.
    all this things will play an affect on the octane required
    hope this helps,oh yeah elevation also.good luck
    Hooli,
    I know a guy that runs on Av Gas with 12.5:1 with no problem's but 12.5 is not 14:1 that extra point and half might kill ya. With an engine that close to the borderline I'd run the known quanity of the C-12 vs Av gas.
    Good luck with that baby.
    Sleeper CP
    Senior Member wajetboy's Avatar
    Auburn, WA
    looks like you are the one that bought the alum boat with the lightning, that is a cool boat. i ran 12.5 to 1 with iron head with no problems on avgas
    1978 Southwind Tunnel Dragster/1980 SWTD center steer
    Gone
    Sparks, Nevada
    Quote Originally Posted by RiverRacer View Post
    I had the same results as others did in PGF. And we were above 14.1 compression.
    Senior Member Dunaholic's Avatar
    Get 100LL from the airport. That's what most planes run on and it's 110 octane.
    Quote Originally Posted by Dunaholic View Post
    just left my local airport getting some 100ll, its definately 100 octane, or at least that's what the lil sticker on the pump said.
    Thumbs up
    This is all I have on the motor right now
    Chevy Bowtie Block 468 CI, 14 -1 compression
    Eagle Crank
    BRC Rods
    JE Pistons
    Donavan Gear Drive
    Brodix BB2xtra Heads
    Manley Valves
    Jesel valve train
    Crower Cam and Lifters
    Dart Tunnel Ram
    Dual 850 cfm holleys
    MSD ignition Marine 7AL
    I'm not sure 600 ish a day to run it is gonna fly to far with the wife..
    I'm waiting fo the build sheet from the last owner. As soon as I get my mits on it I'll post the info. Thanks for the replys.
    Jeff
    Thumbs up
    That's what I was told as well.
    Senior Member Futs's Avatar
    Orange CA, Big River
    run alky and be done.
    thinking about it myself, it'll be cheaper to run soon enough
    i've been wondering about busby's torco octane booster i've seen. has anyone used it yet? supposed boosts alot, but noone has stepped in to say how much or if it helps.
    OOPS!!!! I meant that it was 100, not 110.
