Holley fuel inlet thread size???? Please Help!!
    Redding, CA
    Default Holley fuel inlet thread size???? Please Help!!
    I need a couple fuel inlet adapters for the new 6109's I built.
    They have 4 side hung primary bowls.
    I am placing what I hope is my final order for the last little stuff and I do not know what the thread size is for the bowls.
    The OD of the threads for the 2 6AN fittings I have that fit are 0.555 on the thread OD.
    The ones I am looking at on Summit do not state what bowls they fit.
    What is the thread size for the Holley side hung bowls??
    I'm thinking it is the 9/16 24 ??
    Thanks!!
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    All of my Holley's use a 7/8-20, but there are also fittings listed for Holley that are 9/16-24, which is what your measurement would appear to translate to.
    7/8-20 = center pivot bowls dual feed 4150 carbs (like double pumbers and Dominators)
    9/16-24 = side pivot single feed 4160 carbs (like 660, and 1850) the 6109 requires two fitting per carb. Also fits Q jet
    Redding, CA
    Thanks Guys!
    I have a Holley 4150 on the shelf with center floats and it has the bigger inlet (7/8")
    I converted the metric ones to decimal (in.), nothing was close to that OD, the 9/16 24 is the only one that was even close.
    Thanks again for confirmation!!!
    Tommy
