Bellhousing for top mount starter?
Results 1 to 11 of 11
    Jul 2010
    Lubbock, TX
    Default Bellhousing for top mount starter?
    Hey guys, just wondering what my options for bellhousings are.
    I need a bellhousing for a SBC to fit a top mount starter. The engine is mounted with motor plated, so I do NOT need the bellhousing to do anything other than cover the flexplate and hold the starter. Also, my motor plate is about 3/8" thick; so I need that factored in for the starter spacing.
    Ideally, it'd also use the driveline cover I already have.
    What are my options?
    "No, my boat doesn't need any more power" - No one ever
    Kingman/Golden Vly, Az
    Quote Originally Posted by FormulaZR View Post
    Hey guys, just wondering what my options for bellhousings are. I need a bellhousing for a SBC to fit a top mount starter. The engine is mounted with motor plated, so I do NOT need the bellhousing to do anything other than cover the flexplate and hold the starter. Also, my motor plate is about 3/8" thick; so I need that factored in for the starter spacing. Ideally, it'd also use the driveline cover I already have. What are my options?
    good luck with that!...i personally have never seen one for a SBC...maybe the SBC gang has one laying around or suggestions ...just sayin' FastRat
    Jul 2010
    Lubbock, TX
    I believe SBC and BBC would use the same bellhousing/starter, wouldn't they?
    Maybe there are different types of set ups. With my top mount deal the bellhousing didnt suport the starter at all. There was a seperate starter stand that had to 1/2" bolts(i think) and one smaller bolt kind of on top...was a lightning set up. The back plate was 1/2" thick and threaded for the starter stand bolts...if that makes sense.
    Jul 2010
    Lubbock, TX
    Do you have any pics of your Lightning setup?
    i dont know for sure, but, if thats the case, there are a couple of top mount starter bellhouseings for sale in the Parts Forum...just do a search & take a look at them ...just sayin' FastRat
    I will se if I can find an old one an edit a pic in....dont have it anymore. I got frustrated with the inability to shim away(up and down) like you have with a bottom mount. Was always too tight.....put on some offset dowles and got it perfect.....then replaced my flexplate after that and it was too loose...then I gave. In hindsight....aparently if I would have replaced the flexplate 1st I probably would have been golden. I had some issues with a certain top mount starter company also....but thats another story.
Name:	Starter stand.jpg
    This is what a starter stand looks like...just dug this out of a corner of my garage.lol
    Another reason I 86'd mine was for clearance. After I glassed my transom back in from the guy before me....I barely have an inch for my ski tow. =)
    Placentia, CA
    Both SBC and BBC use the same bellhousing.
    steveo143 AKA DiMarco 21 II
    Quote Originally Posted by steveo143 View Post
    both sbc and bbc use the same bellhousing.
    bingo!
    Jul 2010
    Lubbock, TX
    After some research, it appears that none of the bellhousing with top mount starter provisions are designed to work with a motor plate, except Lightning's which uses their motor plate. Does anyone know if there is one that will work with a 3/8" thick motor plate?
    Jul 2010
    Lubbock, TX
    Also, could anyone help me out with a measurement? What is the distance between the bellhousing "face" of the block and the front of the flywheel on a SBC or BBC? I'm asking because the flexplate of my LS1 is dished compared to a traditional SBC flexplate - so I'm wondering if there are going to be some differences in trying to get a top mount to fit correctly. If you are running a motor plate, I'd be happy with the distance of the motor plate to the flexplate plus the thickness of your motor plate.
