489 bbc ignition timing?
Results 1 to 14 of 33
    Las Vegas, Nv
    Default 489 bbc ignition timing?
    I am looking for a starting base line for Ignition timing on My 489cid bbc. i am running a MSD ready to run dizzy and timing is not locked out.
    I just want a place to set it now while i can run it on the trailer and test and tune on the water. Once I insall the pump I will not be able to play with it on the trailer, With out the headache of disconecting the drive line.
    Senior Member vee-driven's Avatar
    Lomita so. cal.
    36 degrees full advance
    It's not that i don't care, I just dont give a sh!t!
    I have a 489 with iron headed closed chamber heads, a tiny ass 256* @ .050, 12.5 to 1 pistons and run it on 87 octane. Do you think that 36* totall will work for me as well?
    Jun 2010
    Splain it BOB...please I know you can...
    Las Vegas, Nv
    gn7 will You elaborate. I am just looking for a place to start. A place to set it before I get to the lake. Its a fresh motor and has not been on the water Yet.
    Explain what? I'm the one asking the question. I need the explanation
    Hi Bob.
    I can't give you a place to start. Now if your just trying to light it off in the drive, 28 works no different than 38. Once you set the idle, I doubt you could tell the difference between the two. But if your looking for a setting to run on the water as a starting point, the fuel octane, manifold/carb(s), cam, head type(open/closed) material iron/alum are alll things you kind of need to know to make a reasonable intelligent guesstament
    Las Vegas, Nv
    What are Your thoughts on a starting point?
    Las Vegas, Nv
    489 C.I.D.BBC Full roller.
    .030" over bore
    Scatt 4340 forged crank,4.25" stroke
    Splayed main caps /w ARP main studs
    Eagle, 6.135" forged H beam rod's
    SRP forged pistons, 17.00cc dome
    Block,zero decked
    Bullet roller cam, duration- in. 264/ex 273 @.050, lift - int .720/ex .710, 108 seperation
    Morel pressure fed solid roller lifters
    Cloyes hexadjust double roller timming set
    AFR 325cc aluminum heads, milled, .030 for compression bump
    Crane gold rockers,1.8 int.,1.7 ex
    Edelbrock TR2 tunnelram
    two 600 cfm holley carbs
    100 OCTANE
    Any thing else? Oh yea Here is the cam card.
    Las Vegas, Nv
    No skiing or tubeing, jet boat ,73 kona, friendly river racing.
    Shorten the curve way up,like 22-24 intial and 34 total. Make a custom stop bushing if you have to. Or just lock it out and see how it starts. That combo will love 34 degrees locked. But for now I think there is 22-24 degrees built into that dist. so set it at 8-10 degrees initial. But its not going to idle well.
    Close to the water...
    .030" over bore
    Block,zero decked
    100 OCTANE
    Nice Job
    I see you put a few bucks in that,but I would spend a little more
    If you have a chance to run it on the dyno, I would for peace of mind
    I would start at 34 make a couple pulls check the jetting and recheck the valve settings
    And add a degree of timing at a time and watch the dyno #
    Good luck with your project
    Jan 2011
    Mickleton, New Jersey
    gas or alcohol? blown or normally aspirated? put it on a dyno. you won't be sorry
