Head Stud Question
Results 1 to 6 of 6
Head Stud Question
    031 RIVER4FUN's Avatar
    Default Head Stud Question
    I have a Dart block and AFR heads. The 4 bolts/ studs that go from the block to the heads from the lifter valley weren't in the ARP stud kit. Anyone have a part #?
    they never are, some just use a grade 8 socket head (allen) cap screw
    Makes sense. Thanks
    Quote Originally Posted by RIVER4FUN View Post
    I think Dart and ARP both make the kits. With a Dart block you may have to grind a bit for clearance, real good to check before you clean and assemble the bottom end.
    waterloo
    Dart does indeed have a stud set for the four inner points. It is about 90 bucks. There is a stud that screws into the head...not just a bolt. Comes with a funky "U" shaped washer and a 12 point nut. If you are unable to find the dart p/n I will track it down.
    try a p.n 64210240
    Wags
    Concord, CA
    Default dart
    I used grade 8 allen head for mine.
    Also had to clearence the humps for push rods.
    Jerry
