Pertronix ign on bbc
Results 1 to 3 of 3
    Under yo mommas bed jangles's Avatar
    Marana, Az
    Default Pertronix ign on bbc
    Wondering how much of a draw off the batt running with no alt would be. I dont have anything else running, stereo etc, that would draw it down. Any guesses?
    "Thanking Obama for killing Bin Laden is like thanking Ronald McDonald for the hamburger.
    Thank the SEALS NOT the CLOWN.
    Official Member IttyBittyTittyCommitee
    http://newsbusters.org/
    Quote Originally Posted by jangles View Post
    If all you did was install a points to Petronix conversion, it is no different than when it had points. The conversion is nothing more than a proximity sensor switch. What ever your draw was before, it will be the same. What is that? Who knows. Figure about 1 amp hour per 1000 RPM. No that you have that, what does that do for you? By the way, points type and HEI induction ignitions are very sensitive to voltage drop. As the voltage goes down, it kills the battery quicker, and the spark energy goes in the toilet. Bet that isn't something you wanted to hear. On a 12V system, the amount of spark energy from a induction ignition with a alternator VS without, is huge. Even with a fully charged battery. And it only gets weaker as you drive it.
    Marana, Az
    Well I guess I'll be putting an alternator on it. Thanks
    jangles
