4.0 whippled 540 dyno results
Results 1 to 14 of 14
    Frozen Hoser Airpacker's Avatar
    Aurora Ont.
    Default 4.0 whippled 540 dyno results
    540, afr 357cnc heads, crane 268741 hydraulic roller, whipple 4.0
    1102hp at 6000.
    peak torque at 3400 was 1075 lbft and it held over 1000 to 5800.
    Member mikes280's Avatar
    charlotte nc.
    nice motor very close to mine and right at the same power
    Somewhere between Paso & L.A.
    would be curious to see the results with the 335cnc's at that rpm, with everything else the same- those are some good #'s tho
    Is that a 8.1 based engine?
    Aurora Ont.
    Quote Originally Posted by MACHINEHEAD1 View Post
    Dart Big M.
    cfm
    cfm is offline
    Good job.
    What kind of boat is it going in ? Make sure to come back and let us know what the boat does.
    What boost, compression, and type of fuel ?
    Aurora Ont.
    Good job.
    03 25 Daytona
    10psi, 8.2:1 ON PUMP 91
    Hopefully water testing tomorrow.
    Close to the water...
    Quote Originally Posted by Airpacker View Post
    03 25 Daytona
    I was wondering why you didn't go with a 5 liter screw blower
    Was asking about the 8.1 because the cam PN says 8.1. I guess you were using this cam for the 4-7 swap firing order? Very impressive @ 10psi
    Aurora Ont.
    height difference. I would have preferred to but my buddy wanted to keep it all under the stock hatch.
    Aurora Ont.
    yes, its a cam for a 8.1. Double firing swap creates friendleir harmonics
    Aurora Ont.
    water tested this weekend. first crack, -2 sportmaster lower with 1" spacer, 1.36 gears, 32 labbed bravo.
    119 bouncing the limiter at 6100
    I understand, good power #'s
    We have a couple of conversions from the quad rotors to the 5.0 liter in the winter work schedule for us to think about
    Your boat is hauling the mail , bravo's are a good overall prop for the money, but at the power level you are at I would try some better props for sure, maybe a 5 blade herring hydromotive,BBlades
    Senior Member Skydog's Avatar
    Jul 2010
    Thumbs up
    NICE NICE NICE!!!! Should have mine next week buddy!! You looking great now prop up!!!
