BBC Cometic Gaskets
Results 1 to 8 of 8
BBC Cometic Gaskets
    Colfax, Ca
    Default BBC Cometic Gaskets
    Can the Cometic BBC MLS gaskets be reused??
    Is this real or the "Twilight Zone"?
    El Cajon, Ca.
    Other than being in a pinch, like having to pull a head at the track/river, I wouldn't recomend it.
    The Bostick®
    Feb 2011
    Wash.
    NOT A GOOD IDEA..
    waterloo
    I don't. However, Cometic says you can. If you do, I'd ceretainly keep same gasket on same side.
    Wags
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    I have and yes they are designed to be reused. . Put some permatex #2 around wherever the coating came off around water jackets.
    Anymore I use the felpro MLS gaskets. They are a 1 shot deal.
    QE 439 Twin Turbo
    Douglas, MA
    Wags
    this
    Somewhere between Paso & L.A.
    Info, is there a reason your using the fel-pro's now over the cometics? which do you prefer,
    and why? I haven't had a problem yet with the cometics, (except for the price) but I don't
    build anywhere near the volume of engines that you do, so I know you switched for a reason!
    Senior Member HomeBlown57's Avatar
    Apr 2011
    I have had one set on my twin turbo small block for about two years. I have removed the heads 3 times and reused the gaskets each time. I clean them and spray an even coat of copper spray on them each time. I also run them on the blown BBC in the boat but haven't needed to remove the heads yet. When I do, it they show no signs of trauma I will reuse them. The sbc is iron to iron. The BBC is aluminum to iron.
