8-71 Blower Belt Questions
Results 1 to 5 of 5
    Junior Member www.rpphobby.com's Avatar
    Jul 2011
    Default 8-71 Blower Belt Questions
    I wanted to ask if Kevlar Blower belts are prone to making more noise than a rubber belt? And do they make less of a mess? Stronger? Thanks for the input.
    8 mm stuff . Yes to all three questions
    Jul 2011
    So you you get a stronger belt, less mess, but draw back is a noisy belt?
    waterloo
    I have only been running the same kevlar belt since 1993. 8mm
    It still has some "dust" or whatever. Not tons. My belt is not what I consider noisy. Over tighten it and you can make some noise. Its also hard on main bearing and blower bearing.
    Wags
    Hmm... is the "dust" from the belt or the pulleys?
    Senior Member bp298's Avatar
    LHC
    Wags
    thread jack...
    how was kentucky lake this weekend????
