Crank to cam centerline measurement BBC
Results 1 to 11 of 11
    Dec 2010
    Sapulpa ok
    Default Crank to cam centerline measurement BBC
    I'm lookin to put the largest blower pulley I can on the crank. Need an accurate measurement from the center of the crank snout to the center of the cam std location not raised. I cant get in there to get a good reading without removing a bunch of stuff. I'm hopin I can get a 89-90 8mm in there the fuel pump drive had been cut out for max clearance. Dont want to buy a pulley to find out it won't clear. Thanks Craig
    Kent, WA
    I have a 99t on one of my engines. Uses a RCD fuel pump ext that I sleeved and then milled for clearance.
    I can send you pics of that or even send you a 90 and 99 tooth pulley to use as mock up if you want ?
    I have the BBC blueprints at home, if you want the drawings, sent me a pm with your email address and I'll mail them to you !
    Wiz
    8mm pullies are measured for the most part as 60t measures 6.0, 80t measures 8.0, 89t measures 8.9 etc
    Junior Member p.higgins's Avatar
    Quote Originally Posted by piston in the wind View Post
    5.150" is the std. cam to crank distance on a BBC
    5.150" is the std. Cam to crank dimension for a bbc.
    Dec 2010
    Sapulpa ok
    Quote Originally Posted by p.higgins View Post
    Thanks for the help !!! Craig
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    7.60's not quick enough for you?
    8 sec class must really be tough. lol
    QE 439 Twin Turbo
    Kent, WA
    Here are the BBC drawings.
    I can email them to you directly if you send me an email address !
Name:	BBC Dims Front and Bottom.jpg
ID:	127122   Click image for larger version.
Name:	BBC Dims Front.jpg
ID:	127123   Click image for larger version.
Name:	BBC Dims Mains and Pan.jpg
ID:	127124   Click image for larger version.
Name:	BBC Dims Rear and Decks.jpg
ID:	127125   Click image for larger version.
Name:	BBC Left Deck.jpg
Name:	BBC Right Deck.jpg
    Thanks wizbang. Those can be a huge help sometimes. They are now posted in the Tech Link Sticky at the top of the "dyno forum" front page
    Jun 2010
    Good job -Bob!
    Dec 2010
    Sapulpa ok
    Well the way I see it is I better make more power so Jeff can see when u bolw that pop off. His eye's are gettin bad & he cant hear $hit. I just tryin to make sure he dont ram u in the a$$ when u lift.
    San Francisco Bay Area
    Cool
    It's been my understanding that the dimension in question is 5.152" (Gen 2 blocks raised to 5.552").
    LO
    High Flow Dynamics
