Oil Cooler ???
Results 1 to 14 of 24
Oil Cooler ???
    Bullhead City, AZ
    Default Oil Cooler ???
    I have this oil cooler, http://www.e-performancemarine.com/i...&productId=236 , it seems that it is leaking water into the oil. Where can I send it to be fixed ?
    Thank you
    Jim
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Rollin With Fink fasterthanu's Avatar
    Norcal
    Quote Originally Posted by Squirtin Thunder View Post
    Thank you
    Jim
    Prolly cant be fixed Jim. Just send it to me and I'll throw it away for ya
    Any competant radiator shop should be able to...
    Quote Originally Posted by Hallettbutt View Post
    Bingo:
    Been there done that..............
    Sleeper CP
    Bullhead City, AZ
    That there is the problem here in this town. There is not one that is competant. So is there one that someone know that can handle this for me ?
    Thank you !
    Jim & Amanda Rich
    CJ 72 & 53c
    Default Test??
    Thank you !
    Jim, DID you TEST it with regulated air pressure YET????? If so, explain what happened..........Ray
    PS if you recall, with the water lines disconnected and the ends wide open, it did not leak oil. Oil pressure is more than water pressure, so how is it leaking water in, but won't leak oil out???????........Test it...........
    LOUD BOATS SAVE LIVES
    jim , are you runnin a inlet water pressure bypass valve? sounds like your putting wayy too much pressure on your cooling system
    If it's the rusty ugly one in your picture I would throw it away.
    That don't make ur sight look very good
    Bullhead City, AZ
    Quote Originally Posted by Blue View Post
    Yep that is one of those cast iron ones, they rust quicker than shit. We market them that way so no-one feels they are getting fucked when they rust overnight. Hit the bricks dumb ass ! If you have nothing to add that is constructive don't add to anyones posts.
    Jim & Amanda Rich
    CJ 72 & 53c
    Bullhead City, AZ
    Ray way past that. It is caroded from the salt water here. It needs to be cleaned and then tested again.
    Ray this is a jet boat not a v-drive I have a 9" impeller in my water pump. It pumps lots of water. And you are wrong my water presure can very easly be greater than my oil presure.
    Jim & Amanda Rich
    CJ 72 & 53c
    Bullhead City, AZ
    The funny thing is this cooler has way more miles on my boat than most '80 boats. But for argument sake I run a dump right off the pump with a -8 line. The engine has a -12 as well as the sight blead-off to the headers.
    Jim & Amanda Rich
    CJ 72 & 53c
    Default Salt water?? Long Beach?
    OK. So did it leak?........I realize the drinking (tap) water is kinda salty, but is the river water salty as well?.........Maybe I should look at the picture. I'll be back.......Hey, some famous person said that, "I'll be back"......Now who was that?...........Ray
    PS, I thought it was a picture of yours. That is just a catalog shot.......I saw yours and it was fairly clean, outside. Corrosion will restrict flow, but I can't see it causing a leak unless it ate through the metal, which it didn't or it would leak oil like crazy with the ends wide open.......Tell me about this pressure test..........What pressure? And how bad did it leak?.....Or not?.......Over and out for the night..........
    Bullhead City, AZ
    My cooler is not pictured, if you remember I cleared over the rust so it looked shinny. No leaks as of yet during testing.
    Jim & Amanda Rich
    CJ 72 & 53c
    Senior Member bordsmnj's Avatar
    garden grove / emerald cove
    dude, you should market those ones with the electric fan,lol
    ps those aren't cast iron.
    Quote Originally Posted by Rep. Joe Wilson (R) View Post
    YOU LIE!!!!!
