Corvair on E-85
Results 1 to 8 of 8
Corvair on E-85
    Members only MAXIMUS's Avatar
    Close by
    Default Corvair on E-85
    Thats right! Just switched over my Corvair to e-85. Got the carburator back form Performance Carb in Ontario and Ron did a bitchen job. Bolted it on and ran like a champ. The tunnel ram iced up & the carb was sweating like a pig. Took temp of manifold after running it for 20 min. Temperature on the outside was 50 degrees after sitting a few minutes while I looked for the temp gun. This thing is wedged in a blow up raft that I will be campaining in some white water events next year!
    If anybody needs a good carb guy who knows this stuff call Ron
    Performance Carb
    1408 S Grove ave Unit B Ontario CA
    909-673-1180
    And no Getrdone I don't build my own Carburators. I have to pay somebody for those too...
    Feb 2011
    Wash.
    Performance Carb
    909-673-1180
    Well, it's good to see you are stimulating the economy..That's not a supprise....
    Senior Member HomeBlown57's Avatar
    Apr 2011
    I think Air cooled (mostly desert) stuff would see the greatest benefit from the E85. Tell me more about this corvair project. Or give me a link if you have already posted on it.
    Oh yeah, change that damn avatar! It costs me about ten minutes of laughing 'till I cry every time I see it!!
    My clothes always had dog hair inside them and I couldn't figure out why, until I came home early one day and caught him!
    Apr 2011
    Of all times for a picture not to post!!!
    Close by
    My avatar is a picture of my only son! Click image for larger version.
ID:	128159 With out him its me and 5 girls!
    The corvair is in an old hijumper I restored about 4 months ago. I have had it for 15yrs. Broke a u-joint in 04 at Glamis and after draggin out of the dunes destroyed the tranaxle. Parked it and started collecting parts. Now its mated to a bus trans with a Kennedy adaptor. 16" of travel in the ass & 10" on a beam front end. I added about 120' of tubing to the chassis. All new sheet metal from a friend of mine. Its a pretty cool old car. Looks like a 70's open class buggy. The corvair motor is pretty bitchen. The heads were milled off and had elbows welded to them. Somebody had made a custom 6 tube spider looking tunnel ram with an oil bath plenum and a 2bbl holley. I changed the plenum around and made it a 4bbl with a 650hp. Fair amount of head work, good compression, flat tappet cam from Howards cams. Over all a clean little set up. Makes good torq and will get with the program for an old timer... Click image for larger version.
    Close to the water...
    Maxi, we used to run a class 5 unlimited 2180 motor
    We ran 930 porsche c/v joints to a bus transaxle
    no more trouble
    Senior Member lilrick's Avatar
    Lakewood
    Sweet little ride! How the hell do you get in that thing?
    Close by
    Quote Originally Posted by lilrick View Post
    Lindora??? I had to cut the glass seats and widen the ass department a touch!
