Oooops
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 53
Oooops
    Kent, WA
    Default Oooops
    Ever seen a rod melted off ?
ID:	128163   Click image for larger version.
Name:	Melted rod side.jpg
ID:	128164   Click image for larger version.
Name:	Melted rod 1.jpg
    Nice! You do good work!
    Feb 2011
    Wash.
    Big block turning high rpm???
    Close to the water...
    What happened to the oil
    Jun 2010
    Looks like my daughter was driving shes good at melting rods and making pistons disappear
    Kent, WA
    Puddingstone 2010 K
    I kept it just for a reminder :o(
    You'll note that the crank is a # 6223 Chevy from a school buss :o)
    Need to change your name to waaaaaaaaaaaaaaapow!
    I have all said, when the oil pressure goes south, Carrillos rods and Bryant cranks only last about 1 second long than a stock rod on a stock crank.
    I sure hope that is a Chinese copy of an Oliver on that crank. I guessing a ProComp Oliver copy. They stop making those, possibly due to cost to produce, or Oliver jumped on their asses. Now they copy the Crower.
    If its a real Oliver, we need to talk.
    Peoria, AZ
    Brian, care to share what the initial failure was? Given the looks of the crank, I'm thinking oil pump/pickup/drive?
    Oct 2010
    Lake Dallas TX
    Default Someone say Oldsmobile ? ? ?
    Nicely Done .... but hey the main looks good ..... you might want to try and burn the mains on the next one so it'll look even ....
    Kent, WA
    Sorry to say it was a real Oliver that I bought new.
    It was NOT the rods fault , I'm sure we all agree !
    Kent, WA
    Quote Originally Posted by The Doctor View Post
    Hi Doc, well, there wasn't anything wrong with the dry sump pump, although it had some little pieces of ground up metal in it upon inspection.
    The magnets in the pan were about 5 times the original size.
    This was prior to the data logger working with the mag noise problem, but , on this run was the fix for that !!!!
    Do we think that 1430 degrees in the pipes have anything to do with the outcome of the holes in the pan ?????????
    After this session, we did open up the rod clearances another .001, but the short block of now, is the exact same as it was at this point.
    ( only difference is the larger rod clearance)
    GN7 , what is your thoughts on two things:
    Rod and mains for clearance ?
    Water and oil temps ?
    No, it was not the rods's fault. But what are you going to do for the next engine? As set of Carrillos on a cast crank? Or a Sonny Bryant with a set of Eagle SIR thru bolt SIR rods in a 2 bolt block?.
    Have you ever run those bad ass Ti rockers you guys whip up on a set of breathed on iron GM oval ports? Ever matched a Hi Helix 14-71 to a set of Edelbrock carbs, or better yet, just one?
    The next time you have a set of Olivers (new) that you are thinking of hooking to a stock GM truck crank, call me. I'll send you a set of Scats. The crank will come out in pieces before the rods let you down. You'll tear the nose off the crank before the rods come apart. The crank will flex enough to tear out the main caps before the rods fail. So, please, let me break them instead.
    Brain, don't feel badly though. We did exactly the same thing with almost exactly the same results at Bako in 2003. But it was an stock crank and a set of RPM rods at 350 a set.
    What do I think? You lost oil pressure big time. Ours was a crack in the pickup. Another time the pickup box broke off. Now, when the engine loses oil pressure, the driver goes blind and can't see for 2 hours. lazer to the retina! That ain't temp or clearances.
    Feb 2011
    Wash.
    Was the block plumbed for dry sump system??
    Peoria, AZ
    Quote Originally Posted by getrdone View Post
    Really? Do you even have the slightest clue whom you are addressing?
