Carb VS. EFI
Results 1 to 6 of 6
Carb VS. EFI
    Kent, WA
    Default Carb VS. EFI
    Dec 2010
    Sapulpa ok
    That Nelson is a mad man !! I run that ignition everyone said it wasn't worth a $hit (not from this site though)
    okie, lake Texoma
    Bet a good Carb guy(Like Patrick from pro systems to name one) could have found the same 20 extra hp over what they had & stayed with a carb, maybe more. But you have to admit, thats pretty impressive that little carb sitting up there and coming that close to that top of the line $$$$ EFI system.
    H8-2-W8
    [email protected] first pass
    Kent, WA
    Would the fuel economy be better on the EFI or Carb ?
    Discovery Bay, CA
    When I had my N/A 588 Sterlings built in '05, Mike D'Annibel said that carburetors make a little more horsepower than EFI, but the EFI gets a little better fuel economy and idles better. He wanted $10k more per motor for the EFI, so I went with the carbs........I can buy a LOT of gas for $20k!!!
    Somewhere between Paso & L.A.
    x2- for 20 hp, and alot of extra gas money, I'll stick with my dominator
