Thursday Aug 18
Well I put the Methanol in the tanks and fired it up on the E85 tune.
It ran great as always for a while until the lines were purged out.
I switched the "fuel energy constant" number in the FAST XFI program from .65 for E85 fuel to .43 for Methanol.
It started right up good again and it was a little lean on idle. The O2 sensor reads the methanol just as well as Ethanol.
I richened up the idle and some parts of the map for a minute and it ran good.
Idles just as smooth as Ethanol at 1000 rpm. Great throttle response.
Warmed right up same as ethanol. Didn't run cold like I expected.
Shes ready for the water.
Saturday Aug 20
I ran the boat around for a while today and it ran good on Methanol.
Temp seemed to level off around 140* where Ethanol ran 150*.
After hanging out on the beach for a while other boats were making some passes so as we left I hammered it.
It ran right up against the rev limiter at 7000 rpm and cycled a few times.
The datalog showed WOT for 4 seconds and took it from 30 to 110. Pulled real hard.
I reset the rev limiter to 7500 and tried it again. It still hit the rev limiter. At 7500 rpm it's turning the prop 12000.
The datalog showed 30# boost and that is the limit of the MAP sensor.
Maxxing out the MAP sensor wants to show a fault in the ECU so I have to disable that. sphss
I can certainly see the huge HP potential from Methanol.
It's hard to gauge how much fuel I used but it was noticably more than Ethanol.
Got back home and looked at the oil and doesn't look milky at all.
The fumes weren't as near as bad as I thought it was going to be either.
I need to spend a little more time running it and fine tuning the map. I've only got about 15 minutes into retuning from Ethanol to Methanol so far.
It took me a lot longer to pump the fuel out of the tanks than to switch to the Methanol tune.
I'll save this map and be able to run either fuel.
Saturday Aug 20
