You tell me what you think about this camshaft....
Results 1 to 14 of 38
    Tri-Cities, TN
    Default You tell me what you think about this camshaft....
    741/.715 lift with 1.7 ratio
    299/314 Adv.
    268/278 .050"
    115/115 Centers
    115 Lobe sep
    4.530' bore x 4.750" stroke
    355 Dart Pro 1's Out of the box
    12.5 to 1
    Dart Tunnel with 2 x 750's
    How much rpm do you think this cam will get out of this 604CID engine? Customer was told this is THE 600CID JET Boat cam to use.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    depends on impeller if it is a jet. suspect 6500 maybe a bit less with a A impeller. max hp would be higher then that. does not sound like a good combo but that is your speciality. what are you thinking?
    I am guessing 950HP between 6300 and maybe 6500 on a good day. Might hit 7000 when you mash the button. Depending on the impellor of course. Guessing it is a NOS cam as it does have a 115 LSA on a reasonable .050 number that wouldn't require it other wise and can think of no other reason for it to be a 115 cam. You know the thing is under valved, why the hell would you widen the LSA on a cam with those .050 numbers. The thing can't breath on top with those heads and valves as it is. Its a NOS cam!
    2 750s on a Dart T ram? Really? Didn't know you could bolt carbs that small to a Dart Guess you do that when you plan on living with the button pushed any time your WOT. and your cam looks like that.
    All in all, it may half ass pass as a NOS cam a for that engine, but it sure as hell suffers big time when off the spray.
    EDIT: Where do I pickup my prize. Did you say a custom solid roller complete with Morel lifters?
    New here Beer:30's Avatar
    Bakersfield, CA
    Whew! That's a BUNCH of stroke to be swinging around at 7000!
    Piece of cake in this day and age Beer! 5.5 stroke if I am not mistaken, and a peak HP around 8000. But you are correct, the wrong FORGED crank, and too fond of the button can and will spell disaster.
    LINK 1000+cid =2000+HP
    SoCal
    I dont think it will get to much RPM form that cam with that cubic inch, compression and duration. Seems real small, maybe a good cruising cam?
    Im taking a WAG at 5800.
    Senior Member hotbo's Avatar
    lake Ouachita AR
    i think the SOB sucks,but Ive also been accused of Focking sheep's as of lately
    WFLC
    2011 Performer SS
    built by Scott Seastrom.
    Somewhere between Paso & L.A.
    same duration @ 050 on a 112 * lsa WITH a blower on a little 468 would turn 6400rpm with a AA imp
    Nov 2009
    Yeah well I would have said "DEER" but as you already found out, There @ssholes are to high for ya, and they run way too fast!
    lake Ouachita AR
    you are correct!,ill refrain from De-railing the OP question anymore
    WFLC
    2011 Performer SS
    Close to the water...
    299/314 Adv.
    268/278 .050"
    115/115 Centers
    115 Lobe sep
    12.5 to 1
    Must be a Obama motor
    Nothing will work like it should
    Jul 2010
    Lubbock, TX
    Why that LSA?
    "No, my boat doesn't need any more power" - No one ever
    Bakersfield, CA
    Quote Originally Posted by FormulaZR View Post
    Why that LSA?
    I was wondering that myself. Higher cylinder pressures? Were they thinking of turbo'ing it? At 12.5:1, I would hope/think not.
    Why that LSA?
    I told you why in my first post! Its why its 15* longer on the exhaust as well.
    NOS!
    SPRAY!
    JUICE!
    SNEEZE!
    GIGGLE GAS!
