spark plug gap
Results 1 to 14 of 37
spark plug gap
    WHITTIER CA
    Default spark plug gap
    getting a couple different answers from people on what i should gap my plugs to
    its a blown bbc with a mag and 10lbs a boost spinning 6800.
    any ideas?
    thanks in advance
    okie, lake Texoma
    Quote Originally Posted by SCSRIVERRAT View Post
    any ideas?
    thanks in advance
    .020
    H8-2-W8
    [email protected] first pass
    Whitewright, TX
    Always gapped my plugs at .018 and cut the tips back to the electrode C/L . Then Autolite eventually came out with the tips pre-cut. (Autolite AR 3934) Jocko
    Dec 2010
    Sapulpa ok
    I've allways ran 19-20 mag or msd
    Senior Member bwurst1's Avatar
    Nov 2008
    Roseville CA.
    Pardon my ignorance, but does it make a difference if its a Mag or MSD setup? IDK just asking not trying to be a smartass. If so, Why? what would be ideal for MSD?
    Dec 2010
    Sapulpa ok
    Quote Originally Posted by piston in the wind View Post
    My bad I just assumed it was alc. I have no clue on Gas.
    Quote Originally Posted by bwurst1 View Post
    Yes it matters. No self respecting MSD user would close a plug gap down to 18-20 thou. Tight for an MSD would be .030, with .040 not of of the question. Any wider on a blown deal, depending on the boost, you risk firing the adjacent cylinder instead of the one you want. The spark will jump to the next cylinder in the cap because it is easier.
    But then, no self respecting mag user will utter the letters MSD in a church. To a mag user, MSD is the flithiest 3 letter word in the english language
    Jun 2010
    yes it matters. No self respecting msd user would close a plug gap down to 18-20 thou. Tight for an msd would be .030, with .040 not of of the question. Any wider on a blown deal, depending on the boost, you risk firing the adjacent cylinder instead of the one you want. The spark will jump to the next cylinder in the cap because it is easier.
    But then, no self respecting mag user will utter the letters msd in a church. To a mag user, msd is the flithiest 3 letter word in the english language
    ouch
    Member Boat 104's Avatar
    San Marcos, Ca
    You did not mention what type of mag your using, I run a Vertex have found that 15 works best for me.
    WHITTIER CA
    i run a vertex mag on gas.
    Senior Member 500BBC's Avatar
    CIUDAD MEXICO NORTE
    So what would you recommend as optimum for MSD, 12#'s on AV.
    I never could get a straight answer from MSD.
    "Pot had helped, and booze; maybe a little blow when you could afford it. Not smack, though" President Barack Obama.
    Liberals just chose to ignore relevant information about the world they live in, and then call themselves sophisticated for having chosen to be more stupid than God made them.
    No tighter than .030, and there appears to be no advandage going wider. I used to gap mine at .040 but have since back it down to .035. I think there is more to be gained from trimming the ground electrode back and rounding it off than there is in a wider gap. Besides, .035 is a flame thrower compared to that pissy little .015-.018 from a mag
    Nov 2008
    Roseville CA.
    The reason for trimming and rounding is so the spark is directly exposed to the air/fuel concoction? Is that right? wondering if there's more to it then that. I run mine @.035 without trimming. If there's more there to be gained, I'm all ears. Thanks gn7.
    Thats the idea. Plus the spark can jump to an edge easier than to the flat under side of a standard electrode. Seems to make the biggest gains in NOS deals, with boosted engines gaining some as well.
    Be fore warned, the plugs do not last as long! The "edge" of the ground electrode rounds over pretty quick, and the center electrode does as well. The near edge of the center electrode looks mitered of quick. The advandage is short lived.
