fuel/water separators
Results 1 to 14 of 17
    Senior Member bordsmnj's Avatar
    garden grove / emerald cove
    Default fuel/water separators
    anybody run a perma-cool fuel/water separator filter?i'm going to try an 81000 series filter instead of the usaul fram pcs5062m filter. any thoughts? they both work on the little cast mount thats in the boat. both have 1"/14 threads and the gaskets are the same. i believe the fram is a 12 micron and the perma-cool is a 2 micron. both flow more than enough fuel,12-25 gal per minute. just a little paraniod about the unknown. any experiences shared about these products would be greatly apprecieted . thanks -Jas
    Quote Originally Posted by Rep. Joe Wilson (R) View Post
    YOU LIE!!!!!
    Senior Member wajetboy's Avatar
    Auburn, WA
    i am using a perma cool water seperator with great results. never used one before last year and alway had water in fuel problem, havnt had a problem since i install it.
    1978 Southwind Tunnel Dragster/1980 SWTD center steer
    Colfax, Ca
    Been using them for three years. No problem
    Senior Member KLINGER's Avatar
    redlands/ aha quin
    Quote Originally Posted by wajetboy View Post
    SAME HERE WELL WORTH IT
    Lexington, KY
    Talking
    I just installed one on my boat. Haven't tried it yet, but I'm not expecting any problems out of it. At least I better not!
    HJ
    Boat 502 76Miller's Avatar
    Huntington Beach, Ca
    When you had the problems where you buying your fuel at a fuel dock or from the pump in town ??
    used the perma seperators before with good results, but i've switch to using wix seperators, the 1 i run now will flow 240gph and the filter/seperator element is as big as a lonnnng type oil filter. i've never had fuel flow issues, or water in the carb since using the wix. on occasion water would get by the permacool 1's i used to run. the wix filter and base together were about 70 bucks at the local orielly's , and the base has 1/2 pipe threads, so you can run 1/2 fuel line to and from it
    cfm
    cfm is offline
    The Permacool adapter has big in/out's also.
    Remember, a water seperator does so do to specific gravity (water is heavier than gas) therefore all seperators can't really hold that much water. If the mount nipple is kept same length, a deeper (longer) filter will hold more water.
    Again, they'll hold ounces of water but not keep a bunch of water from getting in to the carb/fi.
    Replace them every season !
    thanks guys.the problem i have is with clearance. i can only run a filter thats under 6.75" long. i'll drain it often. -Jas
    YOU LIE!!!!!
    Denton, TX
    On these can you run; two in-one out kinda deal? basically putting it before the "T"
    Silverdale, Washington
    Jason, I've ran one on our sled for years. Dual 1/2s in and out. I would think one would work great for that monster of yours but do change out the element every year.........john
    21' Daytona DaytonaTunnel's Avatar
    Enumclaw, WA
    Same here, had one for 3 trouble free years. Change it out every year, all good. It feeds my blower engine w/ dual Dom's all day long. Just make sure you get the one with 1/2" in n outs, even if you don't need it now, you may in the future
    Oh, and by the way....if you don't use the extra 1/2" in or outs, make sure the plugs are TIGHT. The pump has a really hard time picking up fuel if they're loose and allowing air in.........don't ask me how I know...
    lol,16 months now and no issues. thanks again. -Jas
    YOU LIE!!!!!
